Old 03-17-2003
moskus's Avatar
moskus moskus is offline
The Creator of Æ, Ø and Å
moskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond repute
Question Punch-in Recording not working?!?!?
I wonder if this is an ASIO-thing...
When I used WDM-drivers (or was it before the 2.2 update?), I was able to arm a track, so when I press Play I could just hit 'R' and I could record on the track.
But now with ASIO-drivers, it's not working! AAARGH! That was the easiest way to record bands playing live, and now I can't do it?
Please, can somebody else confirm this?
Two wrongs don't make a right, but two Wrights once made an airplane...
Old 03-17-2003
dachay2tnr's Avatar
dachay2tnr dachay2tnr is offline
One Hit Wonder
dachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond repute
Re: Punch-in Recording not working?!?!?
moskus - not sure I understand what it is you're asking. Are you saying you were able to arm a track, hit the play button, and WHILE the track was playing back you could hit the R key and punch in an overdub?
I've never seen or used that feature. Also, how do you know when to punch out? Also, I don't understand how this relates to a live performance. I can't think of when you could/would use a punch in for a live performance, because... well... it's live.
For my punch ins, I just highlight the section of the track where the punch is to take place by left-clicking and dragging in the Time Ruler. Then I right-click and select Set Punch Points. This will establish my punch in and punch out points. Then rewind the track to anything before the punch in point, arm the track and click record. Sonar will only record in the selected area.
Or is this not what you are asking.
Old 03-17-2003
moskus's Avatar
Re: Re: Punch-in Recording not working?!?!?
Bingo! And to stop recording, hit 'R' again. The song will continue playing, but not record anymore... It's brilliant!
And forget about bands playing live. It's more a feature like the one you mentioned, but easier to use when you are two or more. That way you don't have to specify a certain time, you just hit R as the song play...
Old 03-17-2003
dachay2tnr's Avatar
One Hit Wonder
OK, moskus. I just tried it and it worked fine for me (learn something new every day ).
I'm using Sonar 2.1 and WDM drivers.
It's a pretty neat feature, although I'm not sure if I'll ever actually use it. I sometimes have a tendency to fall asleep at the wheel while recording, so I can easily see me forgetting to hit the R button the second time to punch out.
I'm not sure if your problem is with Sonar 2.2 or ASIO. I have Sonar 2.2, but I don't have it installed on this machine here at work. If I remember, I'll try it tonight on my home machine. That machine has 2.2 installed, but it is not using ASIO drivers. That could help to narrow it down for you.
Old 03-17-2003
moskus's Avatar
Thanks!
Any other takers? Somebody using ASIO-drivers?
Old 03-17-2003
moskus's Avatar
Ok, it's the WDM-drivers. Just tested it again (damn forgot the Wave-profiler first time)....
Ok, I'll give WDM-drivers one more shot!
Old 03-17-2003
Qwerty's Avatar
Qwerty Qwerty is offline
1K Silver Member
Qwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond repute
Just tested Sonar 2.2 with Aardvark Direct Pro 2496 and found -
- Works fine for MME and WDM drivers
- Appears to work for ASIO, (metronome sounds, record button is depressed on the interface), but nothing is actuallyrecorded when playback is stopped.
It looks as though the file is never created in the Audio Data folder.
Give me a "B", Give me a "U", Give me a "G" - What's it spell?
F@$K!
Q.
<insert something witty here>
Old 03-17-2003
moskus's Avatar
Thank you... the same happened to me.
And I think you're right: It has to be a bug! Long live Sonar 2.3!
Old 05-03-2003
Qwerty's Avatar
1K Silver Member
Unhappy Heya Moskus!
Did you ever find an answer to this one? Or are we waiting in the Cakewalk "Too Hard" basket for the time being?
Ciao,
Q.
Old 05-03-2003
mixsit mixsit is offline
Been Here, Posted That
mixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond repute
..<snip>...
Wow, this is totally cool. I always did it like Moskus said.
... learn something every day.
Wayne
Monitoring at CathouseSound AetherAudio 'Continuum A.D. and TimePiece 'Mini
(formerly S.P. Technology
Old 05-04-2003
moskus's Avatar
Auto-Punch is great when you're working alone, but it can with advantage be left out when you are recording others, IMHO...
