I have always had hard time with the lows...I monitor with Tannoy Reveals (active) and they are pretty shy on the bottom end. I have had them for about 1 yr now, and I can't say I know them too well.
Here is my problem After I get my mixes to sound as good as I can on the Tannoys, I play them back in my car or other systems, and they either sound boomy or lacking details when played at low volume. What do you do to watch the bass? I've heard that nearfields don't go very low, so, are we just out of luck? I do use reference CDs, but, since I can't hear the real lows, is it just a shoot and miss game for me then? One thing I do is to apply low-cut filters on everything besides kick and bass, everything else, I cut out everything at least below 80-100hz. Is there another way to ensure a non-boomy mix? Thanks AL |
If you could also pipe through a regular home stereo reciever and speakers you could do A/B testing while mixing. This of course assumes you have the same problem on a home set up as you do in the car and that the car is not odd in it's carictaristicts...
This seems to work for many people. Good luck... F.S. PS can you pin it on any one instument???
"If Congress can do whatever in their discretion can be done by money, and will promote the General Welfare, the Government is no longer a limited one, possessing enumerated powers, but an indefinite one" James Madison: the father of the Constitution |
i mix quite low most of the time,but I usually crank the amp up a bit to double check the low end.....at high volumes the low end is more revealing on smaller monitors.....
hey, thanks for the replies, guys.
Freudian Slip: what do you mean "pin it on instruments"? oh, is there a good starting point to cut some of the real lows on bass guitar? like 20hz or below? AL |
Lately, I've been checking my mixes with the Sony MDR headphones every so often. They go down as low as 10 hz, so you can tell pretty quick what's going on in the lower bass.
lower limit of human hearing is around 20-25Hz- does it really help to have equipment that will reproduce a 10Hz tone? - just askin- maybe theres a good reason?- i was taght to use frequencies below 35-40Hz VERY sparingly in the mix (thunder)
-jeff |
One sunny thing I kinda noticed is that my mixes usually sound pretty good in them, but not on the monitors....weird AL |
kremitmusic:
thanks for the heads-up on 35-40Hz , I will refer to spectrum analyser on those since I don't trust my ears AL |
Tukkis |
(Ethan not around ?
)Are you sure your room isn't fooling you instead of your monitor speakers ? Do you know what room modes, standing waves, basic acoustics is/are ?? If not, visit the studiobuilding forum.... Herwig |
#12
AL |
#13
Hmm... I don't know Reveals that well, I always tought their bass response was ok.
What's the music type you're doing ? And the system you're comparing with (that shouldn't have its bass controls all the way up btw) I agree on the heaphone check, but I had to learn to deal with the excessive low end in them (even in cheap consumer Sony's) Herwig |
#14
DP,
I check my mixes on a dif computer's PC speakers with a sub in a dif room as well as in my car sometimes. The thing is, I don't set the bass to be neutral in either of them cuz my philosophy is, if commercial CDs sound good on those systems regardless of the bass boost or not, mine should survive those the tests, too. Does that make any sense?? the obvious differece between my mixes and commercial ones is the bass, where their's is nice and tight, and mine sound blury and overall not crispy. I know I am never gonna achieve pro quality but, I would like to get close ![]() AL |
#15
I used to just check the lows on NS-10's, get it up moderately loud and you will quickly learn EXACTLY what is going on down there. I suspect the reveals would be about the same
DrummyQ VST New! Kompound Drums Vol 1 Sample Building Kit REAPER Merchandise REAPER Chat |
#16
Can you guys please let me borrow your monitors/ears/experiences for a min??
I cut/pasted 2 parts that contain bass from this song I'm working on. Please give it a listen and let me know what I'm doing wrong. thanks in advance AL "Bass test" www.nowhereradio.com/a1a2/singles |
