Old 03-15-2003
dmbpettit dmbpettit is offline
Senior Member
dmbpettit is on a distinguished road
16 Bit or 24 bit
I have an Audigy 2 Platinum card so I can record at 24 bit. But when I mix it down to burn on cd the file type is not supported. But if I mix it down to 16 bit, it will burn just fine. Am I doing something wrong? What is the point of 24 bit?
Old 03-15-2003
AlChuck's Avatar
AlChuck AlChuck is offline
Been Here, Posted That
AlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond repute
As far as I can tell from what I heard, the Audigy does not actually record 24-bit files, but it does play them. The Audigy spec sheet is a little misleading.
Standard audio CDs are 16-bit, 44.1 kHz, period.
What's the point of 24-bit? Well, simply put, it's usually a good thing to capture your source with the highest resolution that you can. In the future maybe standard audio stuff will be at 24-bit, and you'll be glad that your source material was recorded there.
That said, there are a lot of arguments about the issues of whether it makes sense to record stuff that does not benefit from the extra resolution (like electric guitars, bass, drums, most voices and most other instruments) since they have energy in the higher frequency parts of the spectrum anyway; others swear that the compromises made by changing the bit depth from 24- to 16-bit prior to burning are worse than the compromises made by just recording at 16 bit in the first place.
If you look through this board over the last few years you'll find a lot of discussion of this issue.
Old 03-15-2003
Paul881's Avatar
Paul881 Paul881 is offline
Look Mom, I can play!
Paul881 has a reputation beyond reputePaul881 has a reputation beyond reputePaul881 has a reputation beyond reputePaul881 has a reputation beyond reputePaul881 has a reputation beyond reputePaul881 has a reputation beyond reputePaul881 has a reputation beyond reputePaul881 has a reputation beyond reputePaul881 has a reputation beyond reputePaul881 has a reputation beyond reputePaul881 has a reputation beyond repute
The new Audigy2 Platignum ex soundcard records at 24/96 and plays back at 24/96 too. Allegedly. Only two years late. All that development resource and they lose the s/card leadership race.
Old 03-16-2003
BluesMeister's Avatar
BluesMeister BluesMeister is offline
Occasional Poster
BluesMeister is on a distinguished road
Cool
Eloquently put. There really is no need to go down the Creative route these days.
I don't think you've purchased a lame duck, dmbpetit, however I suspect that like many others, you may have been misled by Creative's advertising hyperbole.
The Audigy performs well within the limitations of its capabilities. It's a very good gamer's card, but really can't be regarded as a serious contender in the recording card field.
However, you'll probably be very happy with its performance, and that really is the bottom line.
BluesMeister
BluesMeister
Old 03-16-2003
Pedullist's Avatar
Pedullist Pedullist is offline
Stop it, I can't breathe
Pedullist is on a distinguished road
Yeah, the ads were misleading two years ago. "24/96, latency: 2ms"....yeah right!
When it's working (and with the new drivers it finally does) the Audigy 1 works fine. The Audigy 2 has gotta be even better.
Only freaks like us hear the difference between 16 and 24. If we try (hard). Most of our listeners (family, friends, co-workers) won't notice anything.
Call me arrogant, but I can't say I hear much difference in sound between my stuff, recorded with an Audigy, and stuff recorded with 'pro' cards Terratecs, Audiophiles and the likes. It's what you do with it, I guess.
You can push the Audigy to its limits pretty far if you want, I think....
http://www.nowhereradio.com/trojka
http://www.nowhereradio.com/trafo
Old 03-16-2003
moskus's Avatar
moskus moskus is offline
The Creator of Æ, Ø and Å
moskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond repute
I don't have a "very pro" soundcard, and it's only 16/44... And between my card and a SB card there's night and day!
Two wrongs don't make a right, but two Wrights once made an airplane...
Old 03-16-2003
Pedullist's Avatar
Perhaps I'll say the same thing when I replace my Audigy. But it's the end result that counts, and my momma won't notice the difference...I'll assure ya!
I must admit that the difference between the Live and the Audigy was HUUUUUUUUUUUUUUUUUUUUUUGE! So it's probably the same thing when I switch from Audigy to a semi pro card.
The more you know, the more your ears notice. It's quite sad, actually. It means you'll never be satisfied...(well, I am...I'll stick to my Audigy! Better spend my money on other stuff)
Old 03-16-2003
moskus's Avatar
I'm not complaining about that; It means you are learning! And learning about your hobby is a good thing (IMO, anyway)... I have two passions in my life: Music and "my better half", and I allready know what's worth knowing about the last one...
Old 03-16-2003
Pedullist's Avatar
Yeah, I'm not complaining either...
And I should really learn some more about my wife (my better half)...thanks for suggesting.
Old 03-16-2003
moskus's Avatar
LOL!!!!
Old 03-16-2003
James Argo's Avatar
James Argo James Argo is offline
Fancy Rock N' Roll
James Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond repute
Talking
Keep telling your secret about the better half , Pedullist. Maybe moskus will be attracted to put it on the FAQ
Keep Rockin' and Rollin'...
  #12
Old 03-16-2003
Pedullist's Avatar
Smile
My better half is better looking than my...eh....worst half? What can I say, she's HOT!
  #13
Old 03-16-2003
Paul881's Avatar
Pedulist, if your avatar is a self portrait, then I vote you the scariest looking dude on this BB....including Bluesmeister
  #14
Old 03-16-2003
Pedullist's Avatar
But, but, but....
Weeeeeeeehhhh
*runs home crying*
  #15
Old 03-16-2003
Pedullist's Avatar
This is my Backstreet Boy look (at least my wife thinks I'm hot!):
  #16
Old 03-16-2003
James Argo's Avatar
Fancy Rock N' Roll
Talking
...The picture will be official HOME STUDIO LOGO !!!
  #17
Old 03-16-2003
Makkon Makkon is offline
Newbie
Makkon is on a distinguished road
Talking In regards to pic
That is the perfect (Have i got a deal for you pose)
  #18
Old 03-17-2003
dachay2tnr's Avatar
dachay2tnr dachay2tnr is offline
One Hit Wonder
dachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond repute
Wow. Return of the Fonz!!!
  #19
Old 03-17-2003
moskus's Avatar
Explain to me: Who is this 'Fonz' caracter?
  #20
Old 03-17-2003
Pedullist's Avatar
He was very cool...
(never seen Happy Days?)
  #21
Old 03-17-2003
moskus's Avatar
Errrr.... 'cool'?
I'm cool, and I don't look nothing like him!
  #22
Old 03-17-2003
dachay2tnr's Avatar
One Hit Wonder
From the "more information than you wanted to know" department...
Fonz was a character from a TV show called Happy Days. The show aired in the '70's, but was about a bunch of high school kids from Milwaukee in the '50's.
Arthur Fonzarelli (aka The Fonz) represented the "cool kid" that we all knew in high school. Leather jacket, rode motorcycles, got all the girls, and was forever combing his hair (actually he always started to comb his hair, but stopped because it was already perfect).
Of course, the Fonz ultimately ended up being a caricature of a cool kid. This was bound to happen, because everyone knows you can't really be from Milwaukee and also be cool. (But don't tell Acidrock )
  #23
Old 03-17-2003
SteveE9C6 SteveE9C6 is offline
Dedicated Member
SteveE9C6 has a reputation beyond reputeSteveE9C6 has a reputation beyond reputeSteveE9C6 has a reputation beyond reputeSteveE9C6 has a reputation beyond reputeSteveE9C6 has a reputation beyond reputeSteveE9C6 has a reputation beyond reputeSteveE9C6 has a reputation beyond reputeSteveE9C6 has a reputation beyond reputeSteveE9C6 has a reputation beyond reputeSteveE9C6 has a reputation beyond reputeSteveE9C6 has a reputation beyond repute
I recently read the best explanation of why you should always opt for 24 bit. I think it was in the computer recording section here but I can't find it. Basically, it explained the concept of the number of steps between one bit to 24 bit and the enormous advantage in utilizing 24 bit over 16 bit. Sure CD's are 16 bit, but I guarantee that they were dithered to that from 24 bit or higher. Wish I could find that post because it truly was excellent.
  #24
Old 03-18-2003
Jedman Jedman is offline
Senior Member
Jedman has a reputation beyond reputeJedman has a reputation beyond reputeJedman has a reputation beyond reputeJedman has a reputation beyond reputeJedman has a reputation beyond reputeJedman has a reputation beyond reputeJedman has a reputation beyond reputeJedman has a reputation beyond reputeJedman has a reputation beyond reputeJedman has a reputation beyond reputeJedman has a reputation beyond repute
Hey, ask Slackmaster for that post -- I think that was the first post I ever read on this BBS, and it is brilliant! Slack explained exactly why you should get better quality with 24bit recording, even when dithered down to CD quality.
He probably saved a copy or can link it for you....
Jed
  #25
Old 03-18-2003
Toki987's Avatar
Toki987 Toki987 is offline
Rock Steady
Toki987 has a reputation beyond reputeToki987 has a reputation beyond reputeToki987 has a reputation beyond reputeToki987 has a reputation beyond reputeToki987 has a reputation beyond reputeToki987 has a reputation beyond reputeToki987 has a reputation beyond reputeToki987 has a reputation beyond reputeToki987 has a reputation beyond reputeToki987 has a reputation beyond reputeToki987 has a reputation beyond repute
So does that mean the difference I hear in midi from my live to an audigy will be "HUUUUUUUUUUUUUUUUUUUUUUGE"? or is it just pertaining to audio?
" Miwk Kowz "
Kጝ: securelock
