Old 03-11-2003
Musicbreathe Musicbreathe is offline
Newbie
Musicbreathe is on a distinguished road
Unhappy Help routing please (VM88)
How do I rout active speakers on my VM88?
Old 03-11-2003
JR#97's Avatar
JR#97 JR#97 is offline
Engorged Member
JR#97 has a reputation beyond reputeJR#97 has a reputation beyond reputeJR#97 has a reputation beyond reputeJR#97 has a reputation beyond reputeJR#97 has a reputation beyond reputeJR#97 has a reputation beyond reputeJR#97 has a reputation beyond reputeJR#97 has a reputation beyond reputeJR#97 has a reputation beyond reputeJR#97 has a reputation beyond reputeJR#97 has a reputation beyond repute
What do you mean by route? I usually hook monitors up to the monitor outs.
*My Karma ran over my Dogma!*
Old 03-11-2003
Newbie
From The M1MKII manual:
"Since the M1 Active MKII are self powered, DO NOT connect them to the speaker putput of another amplifier (such as a powered mixer or a hi fi receiver). Connect them only to the line-level outputs of such devices"
So.. where again in the mixer?
Old 03-11-2003
sheppard's Avatar
sheppard sheppard is offline
Dedicated Member
Location: I am not going bald goddammit!!I'm just to tall for my hair.
sheppard will become famous soon enoughsheppard will become famous soon enough
most daws have a monitor out on the rear panel.(l/r) this would be the place to connect active monitors.
Old 03-12-2003
Newbie
So you're saying not to connect them to the mixer at all?
Old 03-12-2003
MiXit-G's Avatar
MiXit-G MiXit-G is offline
Designated Drinker
MiXit-G is on a distinguished road
Yes connect to the mixer.
There should be monitor out jacks, if there is only one it would be a stereo type (like for a headphone plug with two black rings) in which case you will have to make (or buy) a lead which goes from a TRS plug to 2 RCA type ones (if your monitors use RCA's)
Ask you local electronics shop what you wanna do and they will supply you with the right lead.
Be sure to set monitoring to "stereo".
Hope this helps.
Old 03-13-2003
Newbie
Unhappy
Thanks! Mmm... here's my dilemma one set of outs is +4 dBu (balanced)
THe other oned is -10 dBv (unbalanced and I need +4 dBu according to the speaker's manual but I want it unbalanced...
I'm so confused...
Old 03-13-2003
turntablist turntablist is offline
Senior Member
turntablist is on a distinguished road
I would like to help but I don't know the difference between unblanced and balanced outs. I have been dying to know though. Someone please explain it to me.
Old 03-13-2003
MiXit-G's Avatar
Designated Drinker
Its all about your cables, balanced cables utilize 3 pins on XLR's and TRS jacks (Tip/ Ring /Sleeve).
Wiring system which uses two out-of-phase conductors and a common screen to reduce the effect of interference. For balancing to be effective, both the sending and receiving device must have balanced output and input stages respectively
http://www.equitech.com/support/wiring.html
http://www.heilsound.com/bal_unbal.htm
Old 03-13-2003
Senior Member
thanks for the links
Old 03-13-2003
Newbie
So it's more or less like the microphones?
I'm sorry, I'm a songwriter and this aspect of things is not my forte...
  #12
Old 03-13-2003
MiXit-G's Avatar
Designated Drinker
I'm so confused...
Why do you want it unbalanced??
  #13
Old 03-16-2003
Newbie
Sorry for the delay, guy I've been doing 10 hour shifts at the job...
I wanted them unbalanced 'cause I thought the speakers didn't have XLR in but they do...
Please, what is a line-level line? Where do I find thsoe in the VM88 mixer...
  #14
Old 03-16-2003
Nelly Nelly is offline
Newbie
Nelly is on a distinguished road
VM88
I used a lot VM88 last 2 years.We also have active monitors with sub.Now I'm working with VF16, but I use the same outputs.
Well you need to connect your monitors to monitor output ,but turn the knob to the left.Don't use XLR outputs,because you have to keep the master slider too low and you can't use LED indicator.It will show very low level.So connect monitor output to your monitors and don't think why you don't use XLR outputs they are better for connecting to another mixer on stage for example
Regards!
nelly
www.popcorn.dir.bg
http://www.popcorn.dir.bg
Music makes me feel truly alive!
