mixing with protools
Ok, right now i uselly bus multiple tracks of same intrument to a stereo aux track. Is there a delay when I do that?
Ok nexts up is! I read this in one of my mixing book. buss all drum tracks and bass track to a stereo track, add compression, forgot what setting. then buss it out to another track and add EQ at about 3-4db at around 10khz i think and around 100hz. Will i notice delay doing this twice?
I own a studio I owe money on. |
Re: mixing with protools
Do you notice any delay when you do this? There are delays when doing these things in a TDM system, but I don't believe it's a problem in PTLE/Free. Compensating for TDM delays is explained quite well in the PT manual. |
i buss it like that so i can add EQ. to just one track.
I use a TDM system, and I don't know much about the native PT stuff. But bussing the sound through an aux channel DOES induce a very slight delay (like a couple of samples, i think). But it is so small, since you are sending all the drum tracks through it, it shouldn't matter.
However, in the second instance, I can't see the advantage of bussing everything to one aux for compression and then on to a second aux for eq. You can put the compressor plug-in and the EQ plug-in (and up to three others) all on the same aux channel. Makes for a tidier virtual mixing board and avoids another tiny delay. |
![]() Unless your using an outboard analog EQ, but then why in the world would you do that? ![]() |
If, as you suggested, you put separate plug-ins on every individual channel, it is far more processor intensive, to say nothing of more time consuming. Anyway, there may be other ways to accomplish the same thing, but toadie's method seems as reasonable as any, and hardly laughable. |
![]() I also believe that if you end up with EQ & comp plugs on every track, you really don't know how to record. ![]() Quote:
I also think it would be a lot easier (and faster ) to just use an insert. |
![]() Quote:
![]() 'Nite, LD. ![]() |
Ah! I get it now!
I must be a little slow these days. Thanks for the heads up, "Brane"! |
