Old 03-07-2003
Danelectron Danelectron is offline
Junior Member
Danelectron is on a distinguished road
A couple of compressor questions
I'm not quite a Newbie, but am still experimenting so here I am.
I'm using a Delta 44 sound card and have mic preamps on all 4 channels. I am trying to record drums and believe I need compression.
My first question is... Do all compressors provide preamp power? I have seen that some do.
What is a descent, resonably priced unit? I would like to use XLR ins/outs. I probably only need two channels for now, but will one day be moving up to more channels.
Thanks for any responses.
Old 03-07-2003
jrosenstein's Avatar
jrosenstein jrosenstein is offline
Dedicated Member
jrosenstein is on a distinguished road
a compressor is not a preamp. there are some units that have BOTH a preamp and compressor (for example, the JoeMeek VQ3), but this does not mean that the compressor itself is providing any "preamp power," as you put it. you can very well get a compressor and put it after your preamp and before your recorder.
Old 03-07-2003
Junior Member
I do understand that a compressor is not a preamp. I did see a Joe Meeks that had Both. Since I have all the preamps I need for now I guess I am asking more specifically...
What is a descent compressor that doesn't provide preamp power?
I am hoping to save a little by getting a compressor only. If it happens that the better compressors also provide preamp power, I would gladly get said unit and offer my preamp units up for adoption.
Thank you for your response.
Old 03-07-2003
TexRoadkill's Avatar
TexRoadkill TexRoadkill is offline
Audio Bum
TexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond repute
The FMR RNC is a pretty safe bet for a stereo comp for around $175. It is true stereo and not dual mono so you can only use it as a stereo unit on overheads or stereo pairs since each channel will share the same control settings.
Old 03-07-2003
Junior Member
Thanks Tex.
I'll look into this. I may end up with something like this on the overheads and get another two channel that I can run each channel mono for the snare/ high hat and the kick.
I appreciate the response.
Old 03-10-2003
Junior Member
Problem solved. I bought two FMR RNCs. These units have great reviews. I'm curious how I'll balance the stereo in the mix (pan the kick to center I guess). It shouldn't be to difficult. Thanks again TexRoadkill.
Old 03-10-2003
Audio Bum
I hope you know what I meant by 'true stereo'. It's going to be tough to use one RNC for kick and snare because they both work off the same settings and one can trigger the compressor to effect the other channel. What you might want to do is just compress the OH or snare and kick on seperate RNC's using one channel each. Then you can use the RNC's again during mixdown on whatever is left. You can also just run some tracks through them and record that onto a new track to use during mixdown.
The RNC would be used either
1 LR- OH's
2 L- Kick OR snare (but not both)
1 L- snare
2 L- kick
OH's compressed at mixdown
Old 03-11-2003
Junior Member
I hadn't thought about that.
This means a kick may compress the snare signal at the same instant?
I've considered micing the top and bottom of the snare, reversing the phase of the bottom mic. One RNC should work for this. I'ld use the other on the kick.
I'll try using the RNCs by both of your suggested methods.
Question...
I'm using Sonar 2.0. How would I route a recorded track through the Rnc to a new track?
Yikes, I may have to read the book! I'll try to save further questions until I get my hands on the units.
Thanks much for your help.
