Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 03-06-2003
Poddy Poddy is offline
Newbie
Poddy is on a distinguished road
Cpu Spikes
Gday all,
im running a pentium 4 2.4ghz, with over a gig of ddr333 ram, and an Echo Audio Layla. According to the vst performance window i was running at about 10% maximum. However if i open an internet explorer window, or open the control panel, or something else i would consider fairly mundane, the cpu usage overload light pops on, and the audio drops out for a second or so. Does anyone have any reasoning as to why this would be happening? Or any work arounds for it.
Cheers.
Old 03-06-2003
NYMorningstar NYMorningstar is offline
Recording Modus Operandi
NYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond repute
The simple answer is don't web surf while you record and mix. The reason behind it is everytime you open a program it reserves some RAM for itself excluding other programs from using it. My guess is the microsoft programs are Ramhogs.
Old 03-08-2003
skankster skankster is offline
Newbie
skankster is on a distinguished road
I have the same problem, and I don't even have internet access or any other programs installed.
I never had the problem until I installed Windows XP. I shoulda stuck with Win98 - but I did have the occasional freeze, and people were saying XP is more stable . . .
ken
Old 03-09-2003
Ashura Ashura is offline
Senior Member
Ashura is on a distinguished road
yo skankster...it sounds like i have almost the same setup as you. I'm on 98 right now, and I have no idea what it is, but I am crashing INCREDIBLY. I literally can't go through a mixdown without crashing at least 3 times per hour. I really don't know what it is, it wasn't this bad before. I opened up the VST Performance and it seems like I'm usually around the 50-60 level, and then it'll spike to 90 and crash. My thought was to move up to XP, actually, but if you're saying its causing problems. I end up with the death screen and end up rebooting, I spend more time with that than actually doing music. I defrag and all but it doesn't seem to work.
How did you get your 98 to work so well? My CPU is top of the line, I don't think its that...did you do much configuration with your Layla?
If you could help me out at all, you got no idea how much it'd make my life easier...
Old 03-10-2003
Newbie
wow - it's hard to know - could be any one or more of a million things - bot here's a weird one i found out about by accident.
try going to options/audio setup/system, and in the audio performance box (upper left corner) and set "number of channels" to 12-16 MORE than you are using in your song. this seems counter intuitive to me, because i thought that more tracks would use more processor power - but for some reason, on my system, if i'm getting close to using as many tracks in the song as i have set in this box, it starts to choke.
while you're there - look at Audio I/O (ASIO Device)) and make sure your drivers are set to the Layla/Darla/Gina ASIO Drivers, then open up the ASIO Control Panel and experiment with raising the buffer size. it'll increase your latency, but that beats crashing all the time.
hope this helps,
skankster
ken
Old 03-10-2003
Senior Member
skankster...thanx im gonna give that a try tonight. i usually do increase the track size and all, along with the disk size below it. and the default for the asio was echo layla/gina/darla.
asides from installing the drivers for the soundcard, have you, or anyone, changed any of the settings for the Layla? have you tampered with any of those configurations to optimize it? I just pretty much installed the layla driver and cubase and worked from there...how much tweaking did you do to the soundcard software?
Old 03-12-2003
Newbie
Ashura -
just so we're on the same page - it's not the track size i'm talkin' 'bout, it's the number of trax. i think that's what you meant, but just to be sure . . .
i haven't done any tweaking to Layla or to the drivers . . . i experimented a bit with the buffer size in options/audio setup/system/asio control panel - i'm currently running at 512 samples (13 milliseconds) but that's about it
yo Poddy - did you ever find any solution to your problem, cuz i'm still having that problem and can't figure it out
skankster
ken
Old 03-12-2003
ALBERTPIKE ALBERTPIKE is offline
Junior Member
ALBERTPIKE has a little shameless behaviour in the past
[QUOTE]Originally posted by skankster
[B]wow - it's hard to know - could be any one or more of a million things - bot here's a weird one i found out about by accident.
hope this helps,
I just noticed the same thing tonight. I switched from 16 tracks to 24 with almost sixteen running, and my VST performance meter fell back dramatically. Go figure!!!
Old 03-14-2003
Newbie
skankster
No im still living with it. I just work around it now. I dont open other applications while Cubase is playing back the song. But i have found it does the same thing when i add another audio track. But not when i open or initiate plugins for some reason. Its a lil annoying but im more than used to it now.
Old 03-15-2003
Bass Master "K"'s Avatar
Bass Master "K" Bass Master "K" is offline
Force of Nature
Bass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud of
Hey guys. I'm not running a layla card, I'm using an aardvark Q-10, but I can say that XP is totally rock solid here.
If your having problems make sure that you go to www.musicxp.net and look for the tweeks that apply to your system. It really makes a difference.
Old 03-18-2003
Senior Member
damn, im still crashing. i bumped of the number of tracks and what not, but its still acting choppy as ever. i really think i might have to move up to xp or at least 2000, but im not too thrilled about doing it mid-project.
  #12
Old 03-18-2003
Senior Member
sorry, bumped UP the number of tracks, not off...i added 16-24 tracks extra like suggested.
  #13
Old 03-18-2003
Newbie
Yeah - I haven't got to the bottom of my problems, either.
Bass Master "K" -
I have applied all those tweaks, and it did help the MIDI timing considerably in XP, but I'm beginning to think I have a Video driver conflict, because the main problem I have is when the cursor scrolls to the next screen in the arrange page (you know - when the song is playing along and it reaches the end of the page, causing a screen re-draw for the next page), both audio and MIDI drop out and the CPU meter jumps into the red briefly.
Ken
ken
  #14
Old 03-18-2003
Randy5235's Avatar
Randy5235 Randy5235 is offline
Senior Member
Randy5235 has a brilliant futureRandy5235 has a brilliant futureRandy5235 has a brilliant futureRandy5235 has a brilliant futureRandy5235 has a brilliant futureRandy5235 has a brilliant futureRandy5235 has a brilliant futureRandy5235 has a brilliant futureRandy5235 has a brilliant futureRandy5235 has a brilliant futureRandy5235 has a brilliant future
Everyone that is having problems try this:
right click on my computer;
left click on properties;
click on the advanced tab;
click in the setting button under performance;
click on the advanced tab here as well;
under processor scheduling set it to backgfround services;
that should help ALOT
i know it doesn't make sense but it does( ASIO runs as a service on 2k/XP) plus the cubase manual suggests this heavily.
Randy5235
  #15
Old 03-19-2003
Newbie
Randy -
Well I'll be a sumbeech - that seems to have helped quite a bit!!!
You're right - it's totally counter-intuitive, but it works!! What's *really* weird is that I had already gone to musicxp.net, and that is the 1st tweak they recommend - but my mind saw it the opposite (priority to applications) - I guess because it seems more logical that way.
Thanks a billion,
ken
  #16
Old 03-21-2003
L'espion Noir L'espion Noir is offline
Force of Nature
L'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond repute
Thumbs up
Thanx for the tips guys
  #17
Old 03-23-2003
Senior Member
hey...im trying to get to these screens, but I'm not seeing anything past the 'Properties' tab on my Computer. I'm running 98, the second release, is this located somewhere else?
  #18
Old 03-24-2003
Randy5235's Avatar
Senior Member
yeah you won't have those screens on w98 but this is something for you to try it should help a bit
Right-Click the My Computer icon on the desktop, click Properties, click the Performance tab, click the File System tab, and under “Hard Disk”, change the setting “Typical Role of This Computer” from "Desktop Computer" to "Network Server".
hope that helps.
  #19
Old 03-24-2003
Newbie
http://forum.cubase.net/forum/Forum2/HTML/030148.html
This is a very useful thread which deals with the problem described here in.
  #20
Old 03-26-2003
Senior Member
so far so good i did some preliminary stuff with it and it's responding alot better than before. im gonna really try it out tonight tho, with the one song that's been a pain, so we'll see.
that thread from cubase.net is loooooong!!!
thanx for the help, really!
  #21
Old 03-27-2003
Senior Member
I tried that song file out and im still seeing the high level on the CPU Performance. would anyone familiar with layla and/or 98 be willing to check out a few screenshots of my setup? maybe its something that I'm just not seeing...
  #22
Old 04-01-2003
Newbie
i'll check 'em out
no promises, but it's worth a shot
send 'em on over
ken
ken
