Thread Tools | Display Modes |
Is there such a thing as a custom cable that connects balanced and unbalanced gear?
Obviously, the best thing to do is to make sure that you always connect balanced to balanced and unbalanced to unbalanced, or you're going to get a nasty ground loop complete with annoying hum. But if you really wanted to connect a piece of balanced studio gear to an unbalanced live rig, how would you go about it? If the answer is a special cable, can you buy them premade?
Thanks in advance.
Wherever you go, there you are. www.chrisfitzgeraldmusic.com |
If the gear in question is electronically balanced, then you don't need any special cable - in many cases you simply wire them together with an unbalanced cable and the connections at the balanced gear end will adjust. You will get a 6dB drop in signal level though....
If the gear is not electronically balanced, the ideal way is to use a high-quality transformer to unbalance the signal. Radio Labs makes them, and so does Ebtech.... I've used the Ebtech and it doesn't seem to affect the signal a whole lot.
bruce valeriani recording articles http://www.bluebearsound.com/images/bb_siglogo.jpg |
Thanks for the reply. The thing I've noticed so far is that the moment I try to connect an unbalanced piece of live gear (in my case, a Raven Labs PMB-1) to a balanced piece of gear, I immediately get ground hum in the output of the unbalanced gear whether the balanced gear is even turned on or not. Would the transformer take care of this? If so, where do I find the ones you mentioned, and how much do they cost?
I've always heard these kinds of "ground loop" issues described as some kind of voodoo called a "Pin 1 problem". I take this to mean that the tip of a TRS plug and the tip of a 1/4" unbalanced patch cable are not supposed to be connected to the same thing, but - as always - I could be wrong.
Thanks, that looks like just the ticket. ![]()
There's a page at the Jensen Transformers site that shows you how to build the adapter cable in 3 different versions from "works OK" to "best way." I have it at work and can send it tomorrow if you like.
DD |
But I think I'm handy enough with a soldering iron to be able to put together a couple of cables....and since this stuff is going to be wired into a 3 space live gig rig for some time to come, I'll be happy just getting it done anyway I can and getting on with life. At the moment, I'm playing with the balanced gear basically ungrounded, which makes me nervous.
Ok here it is. Go to these 3 and print them out (total of less than 20 pages):
http://www.jensen-transformers.com/an/an003.pdf http://www.jensen-transformers.com/an/an004.pdf http://www.jensen-transformers.com/an/ts_guide.pdf If you're really good with a soldering iron take a look at some of these guys: http://www.jensen-transformers.com/apps_sc.html Hope this helps. DD |
There are unbalanced XLR cables out there, but you have to be REALLY REALLY careful into what you plug them into (i.e. a mixer with phantom power
Most mixers don't like shorting +48V to ground...). The unbalanced XLR connectors should look the same as regular XLR cables.. but I'd recommend labelling them so you don't make a smokey mistake somewhere down the line ![]() |
The Raven sould NOT be giving you that kind of noise. (Are you doing an insert or something?) Why not call the company and see if they have any good ideas?
The Raven Labs unit isn't giving me noise - it's the connection between the (unbalanced) Raven Labs blender and the (balanced) EQ that is noisy. Both units, when connected to the proper type of gear, are extremely quiet. Digital Don - Yikes! I downloaded two of those pages, and it looks like I'd have to be wiring capacitors into the cables themselves! If this is the case, wouldn't I just be better off with one of the Ebtech units?
