Go Back   Home Recording > Equipment Forums > Keyboards and Sound Modules
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 03-05-2003
Pacifica604w Pacifica604w is offline
Junior Member
Pacifica604w is on a distinguished road
Stuck key on keyboard.
Hey guys,
I've got an Alpha Juno 2 and it has a bum key. When I strike this particular key, the note produced is extremely loud with no in between. If you strike the key lightly, the note is still at its loudest. Can this sort of thing be repaired cheaply or is there a home remedy for this??
Old 03-05-2003
Gunther's Avatar
Gunther Gunther is offline
Dedicated Member
Gunther is on a distinguished road
Usually velocity sensitivity is done by having 2 switches under the key, one gets triggered before the key is all the way down, and the second gets triggered at the very bottom of the key press.
The keyboard measures the difference in time between the triggering of these two switches and uses that to get velocity data.
What is probably going on is that one of these switches is either dirty, stuck or not working... or some mechanical issue is getting in the way.
If you know your way around electronics, you can open the keyboard and try to clean the switch with rubbing alcohol or electronics cleaner. If there is a mechanical problem, like broken plastic on a key, you can try to repair or replace the part.
If you have an ohm meter, check the continuity of the switches, if there is a problem and cleaning doesn’t fix it, replace the switch. If it is a rubber button switch, forget about ohm meter, just clean the black contact on the rubber with some rubbing alcohol and a toothbrush, that usually does the trick.
Your keyboard might have a different method of getting velocity data, but the above is the most common I think.
It shouldn’t be too hard to fix, but expect to be charged a lot by a shop…
