Old 03-02-2003
MusicMan91's Avatar
MusicMan91 MusicMan91 is offline
Senior Member
MusicMan91 is on a distinguished road
Sequencer Questions?
First of all, can someone please explain to exactly what a sequencer is CAPABLE of? Should I go with a hardware or software type? And how would I go about using it??
Thanks
Chris
Old 03-02-2003
jake-owa's Avatar
jake-owa jake-owa is offline
Banned
jake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud of
A sequencer can record MIDI info. That is the simple answer.
I don't feel like conducting a tutorial online, what you should get depends on your needs. I like hardware so I use the Yamaha QY70.
Here are some links that should give you a better understanding of sequencers.
http://www.geocities.com/SunsetStrip...5821/midi.html
http://www.tsmp.org/elementary/music...musictech.html
http://lmbpc.lincoln.ac.uk/audio/midi.htm
That should do it.
Old 03-02-2003
MusicMan91's Avatar
Senior Member
Arrow
I don't know if you are familiar with it but I currently own the Moog Opus 3 Synthesizer, and I was wondering if something like this would be compatible to a sequencer? If not, are there any ways I can make it compatible to an external one?? So, with a sequencer, I could edit the instruments and then connect the sequencer to the digital recorder, and record it??
Thanks
Chris
Old 03-02-2003
jake-owa's Avatar
Banned
If it has a MIDI in and out it is compatible. With a sequencer you can edit the instruments, tempo, quantization, note lengths...and jsut about anything else you can think of. Then, when it's just right you can record it into whatever you use to record. In fact you can synch up your (digital) recorder with a sequencer easily.
