Old 03-01-2003
scottn5388 scottn5388 is offline
Senior Member
scottn5388 is on a distinguished road
Micing Drums w/ Multi In Soundcard
I wasn't quite sure where to post this, but i figured this was the best place.
I currently submix all my drums in my little Behringer MX1604A mixer and send the main outs to the ins on my studiophile 2496 soundcard. I can get decent results this way but I am thinking of upgrading to a multi-in soundcard (probably the Delta 44). I want to be able to run each mic into the mixer and then run it right back out into the soundcard keeping each channel separate so i can later mix the drums in cakewalk. How can i do this? This mixer doesn't seem to have an out for each channel, just a main mix out and an aux out. Do most mixers aside from my "bargain" mixer have an out for each channel in addition to a main out?
Thanks,
Scott
Old 03-01-2003
AlChuck's Avatar
AlChuck AlChuck is offline
Been Here, Posted That
AlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond repute
Yeah, "real" mixers usually have channel outs as well as aux busses.
The MX1604A can be used for a four-channel interface, though -- 2 channels from the main stereo bus and two from the aux 3/4 bus.
Old 03-02-2003
SPINSTERWUN's Avatar
SPINSTERWUN SPINSTERWUN is offline
?Como te trata la vida?
Location: spinsta1 does not rest upon "it" an essential condition of the subject, a condition that has been detached from the 'they'; "it" is rather an existentiell modification of the 'they', of the 'they' as an essential existentiale.
SPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond repute
I would say exactly the same thing that AlChuck just said.......
spin
Old 03-05-2003
F_cksia F_cksia is offline
Force of Nature
F_cksia has a reputation beyond reputeF_cksia has a reputation beyond reputeF_cksia has a reputation beyond reputeF_cksia has a reputation beyond reputeF_cksia has a reputation beyond reputeF_cksia has a reputation beyond reputeF_cksia has a reputation beyond reputeF_cksia has a reputation beyond reputeF_cksia has a reputation beyond reputeF_cksia has a reputation beyond reputeF_cksia has a reputation beyond repute
yeah and if you upgrade to say 8-track you can do the following:
mics in mic-input 1-8
inserts --> to sc input 1-8
out sc --> line input 9-10 (or something)
send channel 9-10 to your stereo out, which goes to the amp for monitoring everything, 'cause you are not able to send channel 1-8 to the stereo out, because you've plugged something in their inserts, without a returning signal.
In fact you're just using the pre-amps from these channels and channel 9 & 10 for monitoring the in - and outputs of the soundcard.
