Old 02-28-2003
charvel pointy charvel pointy is offline
Newbie
charvel pointy is on a distinguished road
how to direct monitor? help a newbie.
Here's my setup. PC, WinXP, Guitartracks pro from cakewalk, M-Audio DUO usb and sp5b monitors hooked up to line outs on back of usb sound card. Disabled soundblaster pci in computer, have the simultaneous record/playback checked. tracks record and playback great, no way I can find to direct monitor except to press stand alone button on duo. Then I can hear what I'm playing (using a POD) thru monitors, but no longer the recorded tracks from cakewalk. All the items in the win mixer are enabled. Am I missing something here? am I unable to monitor the track I'm recording w/ this product while listening to previously recorded tracks? Help, this ain't like the real thing at all.
Old 02-28-2003
Stealthtech's Avatar
Stealthtech Stealthtech is offline
LOGIC ABUSER
Stealthtech has a reputation beyond reputeStealthtech has a reputation beyond reputeStealthtech has a reputation beyond reputeStealthtech has a reputation beyond reputeStealthtech has a reputation beyond reputeStealthtech has a reputation beyond reputeStealthtech has a reputation beyond reputeStealthtech has a reputation beyond reputeStealthtech has a reputation beyond reputeStealthtech has a reputation beyond reputeStealthtech has a reputation beyond repute
Check your settings in the M-Audio control panel within windows control panel
Old 02-28-2003
Newbie
I've got it set for the mme drivers
is that the problem? the manual says to use those drivers w/ xp. Can direct monitoring in the mix be done at all? clark
Old 02-28-2003
LOGIC ABUSER
This card appears to have a different control panel than the audiophile. But do you have inputs 1-2 and outputs 1-2 active ?
You shouldn't need to use the WIN control panel as that would be for the SB which you have disabled.
And you should be able to use ASIO with win xp, but thats not the problem
Old 03-01-2003
Newbie
should/could I use asio w/ cakewalk guitartracks?
??? what would I gain? clark
