Has anyone made a OS disk using Nero???
Is it ISO level 1 or 2 Mode 1 or Mode 2/XA Do I need to relax any ISO restrictions or modify and of the Volume Descriptors? I've made 5 or 6 disks with various options, all which the MasterLink says are "invalid disk". I created a 2.02 a year ago when I had Easy CD Creator and that one worked perfect. Problem is I deleted that program because Nero had conflicts with it. Any help out there? Joe T. |
Cancel the wizard. Go to the file menu at top left of screen. Select "burn image". It will then let you browse to your image file. After you select your file, it will ask you at what speed to burn. Then hit the burn button. That's about it. My version of nero (5.5.8.1) doesn't require any other information. Al
AEL,
I'm running Nero 5.0 which came bundled with a video capture card. I believe I have tried that. The resulting file doesn't have the same properties as the 2.02 version. I'm trying to re-install Easy CD Creator from my recovery disks but I ended up with some registry prblems and that software doesn't want to run. Maybe I'll just stay at 2.02. I really have no problems. Question though for Masterlink users. This unit is quiet picky about the cdr used. It's not all that hot for Maxell and Imation disks. It makes some loud noises when trying to read these. The disks I've had no trouble with were Samsung Premium cdr 74's. Can't find them anymore. Most of the new cdr's are now 80 min. Does that have anything to do with it?? Joe T. |
