Old 02-23-2003
Ricklh Ricklh is offline
Dedicated Member
Ricklh will become famous soon enoughRicklh will become famous soon enough
Bass tracks without a real bass
I'm a new owner of an MR-8 (about a week now) and just wanted to check with you guys for suggestions on the best way to get some bass tracks without using a bass guitar. Keyboard? Import from PC software? I only have a mic and acoustic guitar and I wanna get some bass but without having to actually buy a bass guitar. Thanks in advance.
Old 02-23-2003
M.Brane M.Brane is offline
Part-time amateur AE
M.Brane has a reputation beyond reputeM.Brane has a reputation beyond reputeM.Brane has a reputation beyond reputeM.Brane has a reputation beyond reputeM.Brane has a reputation beyond reputeM.Brane has a reputation beyond reputeM.Brane has a reputation beyond reputeM.Brane has a reputation beyond reputeM.Brane has a reputation beyond reputeM.Brane has a reputation beyond reputeM.Brane has a reputation beyond repute
Some keyboards have bass samples that are decent enough for demo work, as long as you keep 'em low in the mix. Might be something similar in some of the computer based apps.
Even a cheap bass will sound better than fakin' it IMO as long as you have a good direct box or preamp to run it through.
Old 02-23-2003
clifchamb clifchamb is offline
Force of Nature
clifchamb is on a distinguished road
If you want to program drumms at some point there are drum machines that feature bass parts that can be arranged on written on them.
clif
Old 02-24-2003
billisa billisa is offline
1K Silver Member
billisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond repute
ZOOM Rythm Track 123
The ZOOM RT-123 is a nice unit and has a number of solid bass programs that you can "play", program, or use as is in pre-programmed patterns right out of the box. These things run about US$169.00.
Old 02-25-2003
Eric-Jensen Eric-Jensen is offline
Newbie
Eric-Jensen is on a distinguished road
I've tried playing the bass part on my guitar and then using n-track's octave shifter plugin to knock it down after I download the tracks to the PC. It sounds vaguely like an acoustic (guitar) bass, but doesn't stand alone too well. It also is a real CPU hog if you choose more accurate shifting (i.e., decent sounding!). That one plugin uses about 50% or 60% of the CPU on a P3-866, while 4 or 5 other tracks with reverb, maybe a little chorus, and compression use about 10%.
Old 02-25-2003
Garry Sharp's Avatar
Garry Sharp Garry Sharp is offline
Lost Cause
Garry Sharp has a reputation beyond reputeGarry Sharp has a reputation beyond reputeGarry Sharp has a reputation beyond reputeGarry Sharp has a reputation beyond reputeGarry Sharp has a reputation beyond reputeGarry Sharp has a reputation beyond reputeGarry Sharp has a reputation beyond reputeGarry Sharp has a reputation beyond reputeGarry Sharp has a reputation beyond reputeGarry Sharp has a reputation beyond reputeGarry Sharp has a reputation beyond repute
Eric - there's a sort of "off-line" conversion option on n-Track, so it does it while the track is not running and then gives you a wave file of the converted part. Much less demanding on the CPU.
Still sounds like crap to me though (but then I'm a bass player )
Old 02-28-2003
theletterq theletterq is offline
Dedicated Member
theletterq is on a distinguished road
I second the Zoom 123 for a cheap very usable drum/bass machine. It has some pretty darn good bass sounds that can be played in real time or programmed. You can assign any note to any pad to facilitate the particular song you're doing.
