Old 02-14-2003
djc's Avatar
djc djc is offline
I am NOT insane.
djc has a reputation beyond reputedjc has a reputation beyond reputedjc has a reputation beyond reputedjc has a reputation beyond reputedjc has a reputation beyond reputedjc has a reputation beyond reputedjc has a reputation beyond reputedjc has a reputation beyond reputedjc has a reputation beyond reputedjc has a reputation beyond reputedjc has a reputation beyond repute
Copy effects from 1 track to another
Seems I read on one of these threads not long ago how to copy the effects from one track to another thereby keeping the same settings. But I can't seem to find it in a search. I think you hold down the CTL while dragging the effects to the other tracks, but I just don't remember. Anybody remember this?
Old 02-14-2003
moskus's Avatar
moskus moskus is offline
The Creator of Æ, Ø and Å
moskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond repute
Re: Copy effects from 1 track to another
Correct!
Two wrongs don't make a right, but two Wrights once made an airplane...
Old 02-14-2003
Aaron Cheney's Avatar
Aaron Cheney Aaron Cheney is offline
Favorite Chord: C 6/9
Aaron Cheney has a reputation beyond reputeAaron Cheney has a reputation beyond reputeAaron Cheney has a reputation beyond reputeAaron Cheney has a reputation beyond reputeAaron Cheney has a reputation beyond reputeAaron Cheney has a reputation beyond reputeAaron Cheney has a reputation beyond reputeAaron Cheney has a reputation beyond reputeAaron Cheney has a reputation beyond reputeAaron Cheney has a reputation beyond reputeAaron Cheney has a reputation beyond repute
Just drag it. (or is it control + drag?) Sheesh... I do it all the time without even thinking about it. Now I'm at work and can't remember.
Aaron
http://www.voodoovibe.com
Serve the Song
Me
Old 02-14-2003
BibleMan's Avatar
BibleMan BibleMan is offline
Registered User
BibleMan is on a distinguished road
That solution will certainly work. You can also create a separate VMain and place the effect on the VMain. Not only will this place the same amount and type of effect on each track that runs through it, but it takes LOTS less CPU time as you only need one instance of the effect.
-BM
Sonar, a beer and my Tele. Life sure is good....
Old 02-14-2003
moskus's Avatar
Certainly a good idea but I wouldn't recommend that for compression and gate...
Old 02-14-2003
djc's Avatar
djc djc is offline
I am NOT insane.
Wow What a fast response. Thanks guys.
Old 02-14-2003
moskus's Avatar
Well, you know us: We're the best!
Old 02-14-2003
BibleMan's Avatar
Registered User
Agreed. Placing effects on the VMain is only usefull when you wish to use the same exact effect on multiple tracks. I like it for placing reverb on multiple background vocal tracks. Saves tons of CPU cycles.
-BM
Old 02-14-2003
moskus's Avatar
I use the Aux'es for that. It let's you control the amount of reverb you want on the track...
Old 02-14-2003
postalblue's Avatar
postalblue postalblue is offline
Force of Nature
postalblue is on a distinguished road
ditto. i use the aux too. more flexible, although it takes a bit more time to do than routing to the vmain, but anyway.
Old 02-14-2003
James Argo's Avatar
James Argo James Argo is offline
Fancy Rock N' Roll
James Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond repute
YESSS !!!
For :
- Using the Ctrl + drag for copying effect and setting.
- Using the Aux for general effect (reverb, master EQ, analog tape emulator, etc.). It makes all track "mixed" in same room/stage feel. And certainly decrease CPU used.
- Using Compression / gate in each tracks.
- Ten informative reply within minutes is just a positive indication that WE'RE THE BEST !!!
Jaymz
Keep Rockin' and Rollin'...
