sonar 2, drum maps, soundfonts!!!!!!
Hi. I'll try to be brief...doubtful
I have created a drum map where the kit is mapped out to 4 individual audio tracks running different samples thru liveSynthPro. When I initially set it up and save as a template file all is well but when I create a new file using said template the output ports to the LSPro are mixed up. More like rearranged I guess. Instead of the kik going out to LSP 1 it's out to LSP 2 and so on. So nothing sounds and I have to reset the outports. Can anyone help? I did save the drummap in the DMManager. It's an awesome time saving feature for me if it will work. thanks scott. ps; the reason for 4 audio outs is that I run them out of different channels thru a motu 2408. ps2; yeah. It's switching outports 1 to 2 and 3 to 4. I tried moving samples around to accomidate for this and when I did it still swapped outports in the drummap and nothing was right. Very odd. Very odd indeed. Last edited by girvan; 02-12-2003 at 18:24.. |
wierd.
It seems to work, well kind of. I took the file set up with the drum map and loaded sf2's and saved it as a template. When I create a new file based off the template the map isn't working but when I nose down 2 levels to the DrMapManager and select my map from the presets, bango, everything works. A tiny drag that I have to assign the map each time but it still saved me a lot of time in the end. If anyone knows where I'm going wrong I'd be happy to know. later. |
...Well, I dunno what to say, I never do your way of work, But I just couldn't see a thread without reply. I do pay attention to this thread, but sorry, I couldn't tell much...
![]() Jaymz
Keep Rockin' and Rollin'...
Thanks just the same. You did give me that 'email in my inbox with a "reply to post" subject line - kind of good feeling'
later scott. |
A bug?
Well, just for fun I did what you did, created a DrumMap with more than one Livesynth, and you know what?
My outputs are rearranged aswell! It didn't happen if I used DR-008 with more outputs (but that's still one DXi, not many). I tried to use Dreamstation and Sonar would still mix up the outputs. BUT if I used one Livesynth and one Dreamstation it stayed the way it should. It seems that Sonar can't use DrumMaps that routes to different instances of the same synth... sorry.
Two wrongs don't make a right, but two Wrights once made an airplane... |
