Old 02-11-2003
chingon chingon is offline
Senior Member
chingon is on a distinguished road
DIY Insert cables
I need to make some 1/4" TRS insert cables for my mixer, pre's, Compresors, sound card. I want to balance as much of the signal chain as I can. I was planing on using mogami cables but dont know which one to get for this application. I also plan on using switchcraft connectors.
A little guidance please.
thanks in advance
Old 02-12-2003
Senior Member
Come on people, a little help please.
I dont really know which mogami cable i need to make trs patch cables.
Old 02-12-2003
jrosenstein's Avatar
jrosenstein jrosenstein is offline
Dedicated Member
jrosenstein is on a distinguished road
inserts like that aren't balanced
Old 02-16-2003
Senior Member
Ok I did some searching through the forums and now know the difference between patch and insert cables. Would the mogami quad be good for patch cables or should I use something else? What cable would I use for inserts?
Old 02-16-2003
jake-owa's Avatar
jake-owa jake-owa is offline
Banned
jake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud of
Any two conductor mic or instrument cable will work just fine. Just make the connections right. You will need two 1/4" unbalanced plugs and one TRS 1/4" inch plug.
Just think about it...you want the signal to go up the tip (hot) of one of the 1/4" TS cables and through the TRS cable out the tip and back into the ring (in the mixers insert input) then out the other TS cable's tip. The sleve of all three connectors are common ground.
Then it's just a matter of plugging the right way (input or output of whatever gear is being instered into the signal chain)...one way won't work and the other will. The 1/4" TRS will go into the mixers insert either way.
