Only half the keyboard plays sounds!
I have a USB Keyststion 61 key controller.Whenever I record all my sounds shift to either the lower or higher octaves of the keyboard, leaving the other side of the controller blank. This used to happen once I started on track 3 but now it is happening with all my tracks. I have a Roland XV 5050 and I'm running it with Cakewalk Sonar 2.0. I'm also useing a patchlist for the 5050 in Sonar, and I use the editor software that came with the 5050 to set up my MIDI channels. (within the 5050) Any advice would be great. Thanks in advance.
...Well, I found many Roland products separated "Upper" and "Lower" section on several mode. They both set to different channels. I remember when I use Roland E-86, the upper set initially to MIDI channel 4, and the "Lower" to MIDI channel 6. Splitted on certain point/key. Better check your manual again about in what mode you should be to make it "all upper" and the MIDI channel 1...
![]() Jaymz
Keep Rockin' and Rollin'...
... or just select "Midi Omni" in the Input of the Midi-track you're recording on.
Two wrongs don't make a right, but two Wrights once made an airplane... |
