Go Back   Home Recording > User Forums by Brand > Sony Tools / Sonic Foundry
Reply    Audiofanzine Sony Sony News Sony Medias Sony Tests Sony Articles Sony User Reviews Sony Classifieds Ads
Old 02-10-2003
Mountainmirrors's Avatar
Mountainmirrors Mountainmirrors is offline
kaleidoscopic renegade
Mountainmirrors has a spectacular aura aboutMountainmirrors has a spectacular aura about
New Acid User. Input??
Hi-
I just started experimenting in Acid for some fresh ideas. The thing is, certain Acid Loops are shorter than your building blocks in the sequencer. This sounds mechanical and halfassed. Is there a way to shorten your blocks for these short WAVS? How do I make my tracks sound seamless?
Thanks!
http://www.mountainmirrors.com
dark kaleidoscopic folk music for poets, travellers and seekers
Old 02-10-2003
dafduc's Avatar
dafduc dafduc is offline
B O F
dafduc has a reputation beyond reputedafduc has a reputation beyond reputedafduc has a reputation beyond reputedafduc has a reputation beyond reputedafduc has a reputation beyond reputedafduc has a reputation beyond reputedafduc has a reputation beyond reputedafduc has a reputation beyond reputedafduc has a reputation beyond reputedafduc has a reputation beyond reputedafduc has a reputation beyond repute
I'm not sure I'm with you. Are you using Acid software? What do you mean by "the sequencer"?
I've had probs with old pre-Acid loops, where they weren't careful about cutting to an even number of beats. I've been able to solve those by treating them as beatmapped and specifying tempo in Sound Forge.
I still have probs with slowing down loops - lots of artifacts. If I can, I resample them at a lower pitch that corresponds to the desired tempo - as long as I'm not dropping pitch too far, it sounds way better than the default Acid approach.
But it doesn't sound like that's what you're asking.
Clarify, please?
Old 02-10-2003
OK - in track view, when you fill in a block with a loop in whatever sequence you're in. Some Acid Loops are in time, but sound un-realistic because they actually play twice during an Acid measure. It sounds mechanical, because there's an audible space between loops. I've got one loop disk. Just wondering if they're all like this. I'm used to working with drum machines and keyboards. Thanks!
Old 02-10-2003
dafduc's Avatar
B O F
If they're actually "Acidized" loops the tempos should be accurate. Anything you buy from Acid is acidized, and some other loopsellers acidize too. If they're not acidized, Acid takes a best guess as to the tempo - and is wrong a lot, usually by a factor of two. For example, you have a 72bpm sample, it thinks it's 144.
But the duration of the sample depends on the number of beats in it. So a 2-beat sample WILL only be a half measure. An 8-beat sample will be two measures.
I'm not sure where you're getting the extra "space" from - Acid may be misidentifying a single-hit sample as a loop. But just paint it for a shorter duration (you'll probably have to snap to the 1/4 note or quicker) and that will kill the extra hits.
Daf
Old 02-10-2003
SPINSTERWUN's Avatar
SPINSTERWUN SPINSTERWUN is offline
?Como te trata la vida?
Location: spinsta1 does not rest upon "it" an essential condition of the subject, a condition that has been detached from the 'they'; "it" is rather an existentiell modification of the 'they', of the 'they' as an essential existentiale.
SPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond repute
Originally posted by Mountainmirrors
....... Some Acid Loops are in time, but sound un-realistic because they actually play twice during an Acid measure. It sounds mechanical, because there's an audible space between loops. ......
Mm, I am unclear also........... I am still not sure about your question????
I am sure that we can offer you a simple and clear solution to your problem. We just need to be sure what the problem is...........
spin
Old 02-10-2003
Can you make a song sound seemless and un-mechanical in Acid? That's what I'm getting at, I guess. Whether or not to bother looking into buying more loops or just stick with making beats in Fruity Loops and Dr, Rhythm, because I hear an audible "hickup" at the end of a sample during a loop, before it repeats. Maybe the Loop CD I'm working with here is just lame. What's your opinion?
Old 02-10-2003
Mm, I'm answering your question....... it'll take me a few minutes to type, so don't log off.
Peace...
spin
Old 02-10-2003
1) Can you make a song sound seemless and un-mechanical in Acid? .........
2) because I hear an audible "hickup" at the end of a sample during a loop, before it repeats.
3) Maybe the Loop CD I'm working with here is just lame.
4) What's your opinion?
1. Yes, you can. It will take you a little time to get acclimated with the program.
2. There could be a number of reasons for that happenning.
A. The beginning and the ends of the sample might not be truncated properly (zero cross section).
B. The tempo of the song just might not fit with tempo of the sample OR vice versa.
C. How do you have the sample set up????? .......as a LOOP,......as a ONE SHOT,........ or BEAT MAPPED (disc based)?????
D. It will also depend, again, on where you have your start and end points set-up.
3. Maybe
4. It depends on your next post.
Old 02-10-2003
Brad's Avatar
Brad Brad is offline
Back Door Conquistador
Brad has a reputation beyond reputeBrad has a reputation beyond reputeBrad has a reputation beyond reputeBrad has a reputation beyond reputeBrad has a reputation beyond reputeBrad has a reputation beyond reputeBrad has a reputation beyond reputeBrad has a reputation beyond reputeBrad has a reputation beyond reputeBrad has a reputation beyond reputeBrad has a reputation beyond repute
5. (if ya dont mind, Spin...) What loop disc do you have?
I only ask because I bet between the lot of Acid users here, one of us will probably have the same disc and we can check specifically what you are talking about.
Brad
Old 02-10-2003
drstawl's Avatar
drstawl drstawl is offline
5K Californium Member
drstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond repute
This is What Acid is All About!
http://home.adelphia.net/~drstawl/F093d.mp3
Old 02-11-2003
I've got Rapoon Sci-Fi Tribal. It just sounds hiccupy when I loop the samples. Maybe not to everyone. But to me.
Alien Saul is sweet, BTW.
  #12
Old 02-11-2003
I only ask because I bet between the lot of Acid users here, one of us will probably have the same disc and we can check specifically what you are talking about...Brad
I don't use sample discs.
I have 80.000 records AND Sound Forge.
  #13
Old 02-11-2003
Mm, maybe you can send us one of the samples. I'm sure we can rectify your situation.
spin
  #14
Old 02-11-2003
Thumbs up
I guess this is a mute topic. I'll figure it out. Thanks for the help guys!
  #15
Old 02-11-2003
Thumbs up Re: This is What Acid is All About!
BTW.......... very nice track, drstawl.
spinsterone
  #16
Old 02-12-2003
Figured my problem out. Shorten the loop unit using Snap To, then by moving the triangle on to to half. Thanks!
  #17
Old 02-12-2003
Thumbs up
Cool.
