Go Back   Home Recording > User Forums by Brand > TASCAM User Forum
Reply    Audiofanzine Tascam Tascam News Tascam Medias Tascam Tests Tascam Articles Tascam User Reviews Tascam Classifieds Ads
Old 07-12-2000
Casey Gallagher Casey Gallagher is offline
Newbie
Casey Gallagher is on a distinguished road
Question
I bought a Tascam 424mkII second hand, and the guy didn't have a manual for it. I have worked out how to record a track on to 1, 2, and 3, but I can not work how to ping-pong them all down to track 4.I have spent ages fidling around but can't work it out.
If you know the solution I would very much aprieciate it. cheers
Old 07-12-2000
Tim Brown's Avatar
Tim Brown Tim Brown is offline
Why 2K?
Tim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond repute
Wink
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Casey Gallagher:
<HR></BLOCKQUOTE>
While I personally have not used this machine, I've used several Tascam porta studios, and they all essentially worked in the same manner-each just had upgrades.
Put your 3 tracks in tape mode (so you can play and control them with the faders), and not "mic/line/input mode".
Adjust your levels.
Then set track 4 for record mode.
Make sure the other tracks are in the Tape position.
Also make sure that these are in "safe" mode-so that you don't record over these.
Hit play and record.
If the machine is working right-this should put all 3 tracks onto track 4.
Make up some crap tracks to practice with, to make sure that you don't reacord or possibly erase something that you want to keep.
Tim
Old 07-18-2000
MM2 MM2 is offline
Newbie
MM2 is on a distinguished road
Wink
I'm not sure, but you may also need to pan tracks 1 thru 3 hard right to record properly on track 4. [You may already know that in order to record on tracks 1 and 3, you need to pan the input left, while input to tracks 2 and 4 are panned right].
Old 07-18-2000
england england is offline
Senior Member
england is on a distinguished road
Wink
Yeah. Pan tracks 1 thru 3 hard right and set the input switches to 'tape' and set the "record function" switch on track 4 to 'buss r'. Have your faders on 1 thru 3 set, then hit play/record.
Old 07-18-2000
El Barto's Avatar
El Barto El Barto is offline
Dedicated Member
El Barto is on a distinguished road
Wink
Could ping ponging work with stereo recordings too (using an 8 track)? Say I have bass on tracks 1 and 2, panned left and right respectively, and drums on track 3 and 4, again left and right?
