questions
I have some questions regtarding Sonar 2
After installing the midiman keystation 61 controller, I get pops while im playing notes on the keyboard. Does anyone now why? 2) I cannot get drum styles to play. I open a drum style, it shows up as a midi track but i get no sound. 3) How do I get a midi track to an audio track? thanks in advance
"Making the simple complicated is commonplace; making the complicated simple, awesomely simple, that's creativity." -Charles Mingus |
could you give us a little more information about your setup?
1. operating system, motherboard chipset type, processor speed, amount of ram 2. sound card 4. does the midimna have the onboard GM sounds?
" Miwk Kowz " Kጝ: securelock |
sorry...
AMD 1800+ 256 RAM 40 Gih HD Delta 44 SC midiiman usb 61 key keyboard (no onboard sounds) I use it to control the synths within sonar and big tick clav patch
1) Are you using any DXI's and/or have set your latency to low?
2) What MIDI-device have you routed the MIDI-track to play through? Is it to the synth of the card (if any), MIDI-out or a DXi? 3) If you're using a DXi, you could bounce the track. If you're using the cards synth or an external synth, you need to record the track as audio. Create a audio-track and route the audio from the synth to the track. Soundblaster example: In Creative Surround Mixer (or Windows Mixer), select the recording source as "Midi Synth". Now you can record in Sonar. External synth example: You need to connect the synth to the Line In on the PC somehow. In the Creative/Windows Mixer select recording source to be "Line In" Hope this helps! ![]()
Two wrongs don't make a right, but two Wrights once made an airplane... |
![]() Quote:
Hope it helps ![]() Jaymz
Keep Rockin' and Rollin'...
