Go Back   Home Recording > User Forums by Brand > Alesis Forum
Reply    Audiofanzine Alesis Alesis News Alesis Medias Alesis Tests Alesis Articles Alesis User Reviews Alesis Classifieds Ads
Old 02-09-2003
Mastabeta 57 Mastabeta 57 is offline
Newbie
Mastabeta 57 has a reputation beyond reputeMastabeta 57 has a reputation beyond reputeMastabeta 57 has a reputation beyond reputeMastabeta 57 has a reputation beyond reputeMastabeta 57 has a reputation beyond reputeMastabeta 57 has a reputation beyond reputeMastabeta 57 has a reputation beyond reputeMastabeta 57 has a reputation beyond reputeMastabeta 57 has a reputation beyond reputeMastabeta 57 has a reputation beyond reputeMastabeta 57 has a reputation beyond repute
Question Alesis Xt Or Xt20?
:CONFUSED:
Well, I have done some research and cannot find much of the specs on the "Alesis XT" model adat. I know the XT20 is a newer model but I can score the XT for a reasonable price used.
So heres what I gather from the XT20, it has balanced I/O provided threw the elco adapter... does the XT have this?
The XT20 records at 24bits uncompressed... does the XT record at this rate as well?
Any other info would be greatly appreciated about the XT model.
(ie. a webpage or replies)
Old 02-09-2003
Wireneck's Avatar
Wireneck Wireneck is offline
Fretboard Acrobat
Wireneck has a reputation beyond reputeWireneck has a reputation beyond reputeWireneck has a reputation beyond reputeWireneck has a reputation beyond reputeWireneck has a reputation beyond reputeWireneck has a reputation beyond reputeWireneck has a reputation beyond reputeWireneck has a reputation beyond reputeWireneck has a reputation beyond reputeWireneck has a reputation beyond reputeWireneck has a reputation beyond repute
The xt records at 16 bits, i believe this is the main difference between the xt and xt-20. Im sure there are a few other improvements as well.
Old 02-10-2003
eh91311 eh91311 is offline
recordist
eh91311 has much to be proud ofeh91311 has much to be proud ofeh91311 has much to be proud ofeh91311 has much to be proud ofeh91311 has much to be proud ofeh91311 has much to be proud ofeh91311 has much to be proud ofeh91311 has much to be proud of
ADAT XT vs XT20
The primary difference between the XT and XT20 is the bit rate for the A/D and D/A converters. The XT records at 16 bit, 44.1 or 48khz, the XT20 at 16 bit, 20 bit,. 44.1 or 48khz. The original blackface ADAT records at 16 bit, 48 khz only. The original, XT and XT20 all have balanced I/O via the elco.
It's your decision whether or not the XT20's higher bit resolution converters are worth the extra $.
Old 02-10-2003
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
Not only that -- the converters are not only expanded resolution, the sound quality is significantly smoother on the XT20s........
The other big benefits are a more robust transport with faster lock-up/sync times.....
Old 02-10-2003
foreverain4 foreverain4 is offline
1K Silver Member
foreverain4 has a reputation beyond reputeforeverain4 has a reputation beyond reputeforeverain4 has a reputation beyond reputeforeverain4 has a reputation beyond reputeforeverain4 has a reputation beyond reputeforeverain4 has a reputation beyond reputeforeverain4 has a reputation beyond reputeforeverain4 has a reputation beyond reputeforeverain4 has a reputation beyond reputeforeverain4 has a reputation beyond reputeforeverain4 has a reputation beyond repute
the xt20 also has a mode that you can record up to 24 bit. but you loose 2 tracks, making a total of 6 per unit. i have never recorded this way, but i read that somewhere.
Lynn
www.trhrecorders.com
Old 02-10-2003
Newbie
Then its settled...
i'll hold of until i can get an XT20. I read another benefit for having the 20bits as opposed to 16. since most cds are produced at 16bits, recording at a 20bits leaves you with more headroom for when you master down to a cd. say depending on the dynamics, if you record on a 16bit, you may only actually be using 14-15bits. so when you master to cd at 16bits you are only increasing the volume/distortion.
maybe i am confusing this but heres where i found what i read...
UNDER THE, "Why 20 bits?" section
http://www.sospubs.co.uk/sos/may98/a.../adatxt20.html
thanks,
Blue Bear Sound
eh91311 &
Wireneck
Old 02-10-2003
Newbie
WOW! 24 bits hmm, an even better reason to choose the XT20!
thanks foreverain4
Old 02-10-2003
This I have never heard........ (doesn't mean it's not true, but it's news to me!)
Old 02-10-2003
1K Silver Member
i think you have to have external converters that are connected to the adat via lightpipe, as the converters on the adat itself are only 20 bit. i will have to check the manual when i get home.
lynn
Lynn
Old 02-10-2003
1K Silver Member
here it is, straight from the manual of the xt20. on pg 113, in the digital recording concepts section.
"If your application is extremely critical, it is possible to record at 24-bit
resolution on your ADAT-XT20 using external adapters (i.e., the Rane
PAQRAT or the Yamaha 02R). This method takes the “extra” bits and
records them on higher tracks, so you won’t get eight tracks without
using more recorders and adapters."
lynn
Lynn
Old 02-10-2003
Stefan Elmblad's Avatar
Stefan Elmblad Stefan Elmblad is offline
Force of Nature
Stefan Elmblad has a reputation beyond reputeStefan Elmblad has a reputation beyond reputeStefan Elmblad has a reputation beyond reputeStefan Elmblad has a reputation beyond reputeStefan Elmblad has a reputation beyond reputeStefan Elmblad has a reputation beyond reputeStefan Elmblad has a reputation beyond reputeStefan Elmblad has a reputation beyond reputeStefan Elmblad has a reputation beyond reputeStefan Elmblad has a reputation beyond reputeStefan Elmblad has a reputation beyond repute
My understanding is that the ADAT XT has the most reliable transport system of them all. The LX20 and XT20 is somewhat flimsier constructed.
  #12
Old 02-10-2003
1K Silver Member
i have an xt and (2) xt20s. i had the xt last in the chain but i have switch it to the master because the thing sometimes just would not chase the xt20's. didnt happen all the time, but enough to tic me off! lol i put it to master, and, in my opinion, the 20's do a tremendously better job of chasing.
lynn
Lynn
  #13
Old 02-10-2003
No so... the XT20 and the XT have the same more-robust transport - the only difference is the converters...
  #14
Old 02-10-2003
lynn
Well there ya go!
I wonder how many use it this way, though - I don't think it's too common!
  #15
Old 02-10-2003
1K Silver Member
i know, i havent even messed with it. i would rather have 8 tracks at 20 bit than 6 at 24. i, personally, think the difference between 20bit and 24bit is somewhat trivial. i know there is a difference. but not much to the human ear. there is, however, a dramaticly noticeable difference between 16 and 20 bit.
lynn
Lynn
  #16
Old 02-10-2003
Force of Nature
Re: ADAT XT vs XT20
My ADAT XT's got 18bit A/D and 20bit D/A.
  #17
Old 02-10-2003
1K Silver Member
where did you get this info?
Lynn
  #18
Old 02-10-2003
Re: Re: ADAT XT vs XT20
Yes - that's the spec of the converters, but it is functionally only 16-bit....
  #19
Old 02-10-2003
Force of Nature
The specs are in the manual.
  #20
Old 02-10-2003
Force of Nature
Re: Re: Re: ADAT XT vs XT20
What you are saying is that Alesis is wrong about their own converters they developed. Could you please explain this a bit further ?
  #21
Old 02-10-2003
1K Silver Member
the converters are as you say, but it only records 16bit to tape.
Lynn
  #22
Old 02-10-2003
I'm saying that while the A/D chips are spec'd higher, the XT unit is designed and records at 16-bit with either a 44.1kHz or 48Khz sampling rate.
They did not implement a design to match the maximum spec on the chips they used........
Ged'dit???
PS - if you don't believe me, then run a digital signal from tape into a bit-check tool - you will see it is a 16-bit digital signal.........
  #23
Old 02-10-2003
Force of Nature
Is this a effect that happens when it goes to tape or in the converter itself? In other words, if I record I get 16, but what do I get if I only use the A/D's and route a signal from line in to optical out ?
  #24
Old 02-10-2003
I know that when I routed a 24-bit signal thru the the XT20s, it was truncated to 20-bit (even though the signal didn't pass thru the A/D converters), so I suspect it would be the same for the older XTs............
