Programs
What is the best program to produce rap beats in your opinion? What are you using? How does it work for you?
btw... anyone ever used reason 2.0? or do you know what well-known producers use? thanks a lot
Fruity Loops is a pretty cool program. You can get it hella cheap too.
hardware: i've only used my keyboards ( maybe that's the problem)
software: battery from N I |
Heres My List
1-Reason 2-Fruity Loops 3-Acid 4-Project 5 L'espion Noir: How do you use battery, i have it and i dont even know how to use it !! |
![]() spin |
Battery is a pleasure. All my drums and sound fx are triggered though Battery these dayz.
BTW I'm using Cubase 5.1. i checked out a demo of SX, its so different from 5.1 that i didnt even give it a real try.
HDHM - http://www.myspace.com/kbdagrownup The Temperature Of Success Is Cold As Ice |
hi d ho man
sx is cool, but you have to go to the site and check out all of the complaints about it. users of 5.0 have to get adjusted to the new layout. i worked with it for a small time and liked it. the joint has an azz load of vst plugins for you to work with. i choose to stick with sonic foundry because it's simple and to the point.
FL STUDIO 6 REASON 3.04 KNOIZE POLLUTION SOUNDKITS CUBASE SX 3.0 http://www.moneyistherecipe.com/imag...ution-logo.jpg CHECK OUT MY WEBSITE FOR BEATMAKING VIDEOS AND MORE WWW.MONEYISTHERECIPE.COM
fruityloops into acid
use soundforge to tweak the sounds if needed I loved reason but I prefer fruity's interface |
i have the exact same setup ridl
back from the hole
how i use battery
i use my mpd-16 to play the drums samples on my keyboard basically just registering the notes then from sx i load battery as a vst and if the kick was played on the keyboard's D#1 key i load a kick that i want on the D#1 cell of battery et voila did that make sense SPINSTERWUN do you use either battery or the mpd as a stand alone |
