Old 02-05-2003
LDQ LDQ is offline
Junior Member
LDQ is on a distinguished road
Need to seal floating floor.....
Hi,
What can I use to seal between plywood sheets on a floating floor....
Is there some stuff I can buy at Home Depot...
Let me know...
Cheers,
Luis.
Old 02-05-2003
longsoughtfor's Avatar
longsoughtfor longsoughtfor is offline
Searching for the sound
longsoughtfor is on a distinguished road
Hi Luis - I'm not sure what you mean... do want to seal the joints? Or are you talking about adding a layer of something?
Joints can be caulked with silicon or other sealant. Then add your second layer of ply with the joints staggered or oriented 90deg.
HD sells a Pergo product that is for sound deadening that is like a rubber membrane...
Kevin.
Old 02-05-2003
LDQ LDQ is offline
Junior Member
Kevin.
Thanks Kevin,
I need to seal the plywood joints....and I am only doing one layer of plywood for my floor...3/4".
If silicon works for than then... that's cool cause I have some already.
By the way...I have some pics..but I haven't been able to post them because the files are too big....any ideas how to do it.
Cheers,
Luis.
Old 02-05-2003
John Sayers's Avatar
John Sayers John Sayers is offline
Solar Power!!
John Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond repute
Luis you need to get a flooring that has a tongue and groove join. Here in OZ it's called yellow tongue flooring as it has a strip of yellow plastic that links the two sheets. Each side of the sheet has a groove precut into it. You then place the plastic tongue in and it joins with the next sheet. (hard to explain )
cheers
JOhn
