Go Back   Home Recording > User Forums by Brand > Alesis Forum
Reply    Audiofanzine Alesis Alesis News Alesis Medias Alesis Tests Alesis Articles Alesis User Reviews Alesis Classifieds Ads
Old 01-31-2003
deepwater deepwater is offline
1K Silver Member
deepwater has a spectacular aura aboutdeepwater has a spectacular aura aboutdeepwater has a spectacular aura about
HD24 Best way?
Hey guys I own an HD24 and want to know what is the best way to record vocal tracks to it. Do I want to use a tube pre or record dry and then route the signal thru the pre amp on play back/mix down?
Any advise will help
Old 01-31-2003
MISTERQCUE's Avatar
MISTERQCUE MISTERQCUE is offline
Not Just Anutha Brutha
MISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond repute
If you are working with a decent pre, and based upon the info
I have learned from others here, it would be wise to rec'd vocs
thru pre's to the HD. Keep in mind that if you are using a board to the HD, automatically you are running the mic'd signal thru the board's pre's out to the armed track on the recorder.
Also basically, the term "DRY" & "WET" are usually associated with efx processing such as adding 'verbs, pitch,chorusing etc.
For a crapload of info on pre's, go and check out the "RACK" Forum here as seemingly 90% of the threads in there refer to pre-amps!
