Old 01-21-2003
crhblack crhblack is offline
Newbie
crhblack is on a distinguished road
Angry Mixdown to CD Question
Hi,
This is my first post. I have a DAW with Nuendo 1.61 installed. Previously, we tracked to a pair of ADAT XT with the sample rate set to 48K. I was able to dump these tracks to Nuendo and mix them with no problem. I then exported them to 2 tracks per the manual. The resulting 2 track mix plays fine in Nuendo, but when I burn to CD, it sounds like I was playing a 45 r.p.m. wax job at 33 r.p.m. I'm using Roxio EZ-CD creator as my burning software. Any suggestions?
Thanks,
crhblack
Old 01-21-2003
Stealthtech's Avatar
Stealthtech Stealthtech is offline
LOGIC ABUSER
Stealthtech has a reputation beyond reputeStealthtech has a reputation beyond reputeStealthtech has a reputation beyond reputeStealthtech has a reputation beyond reputeStealthtech has a reputation beyond reputeStealthtech has a reputation beyond reputeStealthtech has a reputation beyond reputeStealthtech has a reputation beyond reputeStealthtech has a reputation beyond reputeStealthtech has a reputation beyond reputeStealthtech has a reputation beyond repute
Im assuming you mixed to one stereo track and dithered down to 16bit in a wav file format...correct ??
Old 01-21-2003
Newbie
That is correct. I put the UV-22 as the final plugin in the main master chain. I mixed to a 16 bit wav file.
Old 01-21-2003
Newbie
Nuendo has an internal sample rate converter. During the mixdown to 2 tracks, it converts the files to the specified sample and bit rates.
Old 01-21-2003
Newbie
Good thought, Sonusman. I'll check that out tonight and let you all know. I appreciate the help!
Old 01-24-2003
Newbie
I checked on my mixdowns. They are indeed 44100 sample rate and 16 bit resolution. Interestingly enough, I ran a test. I did a mixdown without any effects plugins and one with the plugins. The mixdown WITHOUT the plugins worked perfectly when burned to an audio CD while the mixdown with the plugins sounded as previously stated. Strange, huh? Any suggestions??
Old 01-24-2003
Track Rat's Avatar
Total Gear Slut
For what ever reason, your resampling didn't go well. It's like it's playing the 48k file at 44.1 with no conversion.
Old 01-24-2003
Newbie
Track Rat:
It is strange. Could it be the plugins? I've read about latency issues especially with Nuendo's group tracks. If you have any suggestions, I'm all ears!
