Old 01-20-2003
sunsoo81 sunsoo81 is offline
Newbie
sunsoo81 is on a distinguished road
Exclamation mic recording problems
hey guys,
im using a computer based recording system, and for right now my ONLY input device is one condenser mic. I put that mic in through a new m-audio omni i/o interface into the MIC/INS XLR jack number 1. Everything so far is going fine, The only problem now is that when i put it into jack one The interface only records and recgognizes the left side! When i switched it to the other plug it defaults to the right side. How do i fix things so the mic will record on both left and right?
thanks.
Old 01-20-2003
maestro_dmc's Avatar
maestro_dmc maestro_dmc is offline
Uses Paramedic EQ
maestro_dmc has a reputation beyond reputemaestro_dmc has a reputation beyond reputemaestro_dmc has a reputation beyond reputemaestro_dmc has a reputation beyond reputemaestro_dmc has a reputation beyond reputemaestro_dmc has a reputation beyond reputemaestro_dmc has a reputation beyond reputemaestro_dmc has a reputation beyond reputemaestro_dmc has a reputation beyond reputemaestro_dmc has a reputation beyond reputemaestro_dmc has a reputation beyond repute
Wow that's an open ended question, as there are a lot of different ways to do what you're after. Why don't you list all the equipment, hardware and software you are using, from mixers monitors computer soundcard etc. so we can be more helpful.
If a kick drum gets hit in the forest and no one is there to mic it, does it make a sound?
Old 01-20-2003
F_cksia F_cksia is offline
Force of Nature
F_cksia has a reputation beyond reputeF_cksia has a reputation beyond reputeF_cksia has a reputation beyond reputeF_cksia has a reputation beyond reputeF_cksia has a reputation beyond reputeF_cksia has a reputation beyond reputeF_cksia has a reputation beyond reputeF_cksia has a reputation beyond reputeF_cksia has a reputation beyond reputeF_cksia has a reputation beyond reputeF_cksia has a reputation beyond repute
Maybe it's a mono input?
And btw; why do you want to record the same mic-signal on two channels? They're both the same!
Old 01-21-2003
nessbass's Avatar
nessbass nessbass is offline
Dedicated Member
nessbass has a reputation beyond reputenessbass has a reputation beyond reputenessbass has a reputation beyond reputenessbass has a reputation beyond reputenessbass has a reputation beyond reputenessbass has a reputation beyond reputenessbass has a reputation beyond reputenessbass has a reputation beyond reputenessbass has a reputation beyond reputenessbass has a reputation beyond reputenessbass has a reputation beyond repute
Cool
Ok, you're a Newbie, so you might not know this:
Cross-posting is a bad, bad thing. Nobody likes reading the same question three times. So please post your question only in one forum.
Thanks.
