Go Back   Home Recording > User Forums by Brand > TASCAM User Forum
Reply    Audiofanzine Tascam Tascam News Tascam Medias Tascam Tests Tascam Articles Tascam User Reviews Tascam Classifieds Ads
Old 09-27-1999
Tiffy Tiffy is offline
Newbie
Tiffy is on a distinguished road
Angry
I'm dumb as hell and probably too lazy..
but can someone explain to me how I increase/improve the levels on each track
of my 424mk2 for mixdown?
I've just tried recodring down and the levels
are way too low.
Old 09-27-1999
drstawl's Avatar
drstawl drstawl is offline
5K Californium Member
drstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond repute
Question
Is it the mix that's too low, or the tracks the mix was recorded from?
Old 09-28-1999
Newbie
Wink
The overall sound of the mix on my hifi is
crappy, too quiet.
Old 09-28-1999
jnorman jnorman is offline
Senior Member
jnorman is on a distinguished road
Wink
gee tiffy - that could be any number of things. take a look at your meters on the tascam as you play back the individual tracks. most of those should be kicking around -3. if those levels look good take a look at the playback level of the mix you made - it should be peaking around -3 to 0dB. if those look okay, take a look at how you are feeding the signal to your system - maybe a bad or misplaced connection. start at the beginning of the signal path and follow it through, and you will find the problem.
Old 09-29-1999
audioforgery audioforgery is offline
Senior Member
audioforgery is on a distinguished road
Wink
I also have an MK2, and have discovered it's almost like a combination lock: in order to get the best sound you really have to experiment with the eq, trim, line-in and effect levels. I suggest that you make test recordings changing every level slightly, in relation to the signal display of each track. Also, do this while monitoring the signal through headphones and watching the meters on the display.
After you've laid down several tests which are satisfactory, it's time to repeat the process when mixing down to an outside source. From here, you'd best read up on Dragon's mixing forum - might begin here: http://www.homerecording.com/mixing.html
Old 09-30-1999
Newbie
Cool
Thanks people, I've kinda sorted the 'problem' out and realise it's just a matter
of experimentation and all that.
