Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 01-15-2003
Heezzi Heezzi is offline
Newbie
Heezzi is on a distinguished road
Removing Echo from recorded vocals
I have recorded these vocals and they have an echo to them. Is there any way to remove the echo effect from vocals?
Old 01-15-2003
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
Depending on how long the delay effect is, a gate might help....
For very short delays, you're SOL........
Old 01-15-2003
knightfly's Avatar
knightfly knightfly is offline
GrouchyOldFartOnBatteries
knightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond repute
Other than not recording it in the first place, noooo...
Hey, I thought this was gonna be EASY!??!
Old 01-15-2003
maestro_dmc's Avatar
maestro_dmc maestro_dmc is offline
Uses Paramedic EQ
maestro_dmc has a reputation beyond reputemaestro_dmc has a reputation beyond reputemaestro_dmc has a reputation beyond reputemaestro_dmc has a reputation beyond reputemaestro_dmc has a reputation beyond reputemaestro_dmc has a reputation beyond reputemaestro_dmc has a reputation beyond reputemaestro_dmc has a reputation beyond reputemaestro_dmc has a reputation beyond reputemaestro_dmc has a reputation beyond reputemaestro_dmc has a reputation beyond repute
Uhh . . . maybe don't record on a kareoke machine?
I know, just sing REALLY LOUD onto a new track and nobody will hear the echo on the first one.
No wait I know: junk it and start over. Yeah that's it!
If a kick drum gets hit in the forest and no one is there to mic it, does it make a sound?
Old 01-15-2003
jake-owa's Avatar
jake-owa jake-owa is offline
Banned
jake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud of
If it's in a DAW just draw an envelope around the desired vocals cutting the echo tails.
Old 01-16-2003
Sure - same result as a gate - but that still won't work on very short delays...
And what about echo tails from a prior phrase that blend into the next vocal phrase...
Best-off re-cutting the track, or living with the delay.........!
Old 01-17-2003
TimOBrien TimOBrien is offline
2.5K Gold Member
TimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond repute
GIGO: Garbage In, Garbage Out
Redo the track.
Old 01-18-2003
volltreffer's Avatar
volltreffer volltreffer is offline
Imply depressed
volltreffer is on a distinguished road
If you still have THE EXACT SETTINGS of your delay and you did not use any feedback (what I do very often), then you might have another solution to work for you.
use your track and send it through the identical delay.
record the delay output only
invert the phase
add to original track until echo vanishes the best
gate in addition to remove the tails
In theory, this should work, but I'ver never tried
aXel
Old 01-18-2003
Newbie
Bad Acositics caused the echo.
Old 01-18-2003
Must've been a huge room for there to be echo and not reverb...
(sound travels roughly 1 foot per millisecond, so for there to be a distinct echo, the room would have had to have been > 32ft!)
