Go Back   Home Recording > User Forums by Brand > MiniDisk Forum
     Audiofanzine Homestudio Homestudio News Homestudio Medias Homestudio Tests Homestudio Articles Homestudio User Reviews Homestudio Classifieds Ads
Old 01-14-2003
donald nolan donald nolan is offline
Newbie
donald nolan is on a distinguished road
mixing boards
i need to know if there is any software that will give me a virtual
mixing board that will allow me to assign different instruments to different channels through a single line in port.
dwn productions
Old 01-14-2003
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
How would that even be possible?????????
Old 01-14-2003
Track Rat's Avatar
Total Gear Slut
Sorry but that's just not possible.
Old 01-14-2003
Son of Mixerman's Avatar
Son of Mixerman Son of Mixerman is offline
Mix Junior
Son of Mixerman has a reputation beyond reputeSon of Mixerman has a reputation beyond reputeSon of Mixerman has a reputation beyond reputeSon of Mixerman has a reputation beyond reputeSon of Mixerman has a reputation beyond reputeSon of Mixerman has a reputation beyond reputeSon of Mixerman has a reputation beyond reputeSon of Mixerman has a reputation beyond reputeSon of Mixerman has a reputation beyond reputeSon of Mixerman has a reputation beyond reputeSon of Mixerman has a reputation beyond repute
Its possible if your only recording one instrument at a time. And then you can mix after all the tracks are done.
But if you want several instruments recorded into multiple channels of their own at once into a line input, that is impossible.
Peace,
SoMm
Old 01-14-2003
Newbie
mixing software
what i want to do is record bands in live performances. what kind of software do i need to do this. i want to use a lap top. also can i get software that will allow me to assign channels if i use multiple i/o ports. and if so how will i connect to the mixing board.
dwn productions
Old 01-15-2003
Mix Junior
Are you talking about recording from the FOH console directly so that you can remix afterwards to make a "live cd"?
To do that you will need as many a/d converters as channels you will want during the recording. You could buy a MOTU Multitrack recording setup and the associated software to run it, but Its highly unlikely that a laptop will be able to do this. It would take a pretty fast computer with a high degree of reliability. Were talking about 1.5 Mhz or faster motherboard, IDE 80 gig hardrive running around 7400 rpm or faster and 512mb of ram on the PC side. The MOTU 2408 will cost you nearly $900 per 8 channels of inputs, this is on the cheap side mind you. The MOTU I believe comes with software for driving it, there are other systems out there but it won't be as integrated. a Digi001 or 002 will do only 8 channels max at a time, but the 001 is $800 and the 002 is $2000. You could buy a HD24 hardisk recorder or Mackie equivalent and it would probably be the best way IMO, just run the buss outputs into it or the direct outs depending on the FOH back panel. How new are you to recording?
SoMm
Old 01-15-2003
Newbie
donal nolan
thank you son of mixerman for your response to my question about mixing boards. i guess the best thing for me to do is to continue recording to a mini disk as long as i get the mix right. so far they have turned out real good i just wanted to have a little more control over the mix when i down loaded into my computer.
thank you donald nolan
dwn productions
