Old 07-05-2000
thewaiter thewaiter is offline
Newbie
thewaiter is on a distinguished road
Angry
Cakewalk folks,
I am experiencing a problem with glitching/stuttering when playing back midi,I'm not sure if it is hardware related or software related and was hoping someone may have come across this before.
I am using Cakewalk pro audio 6 and my pc is a pentuim 2 200hz with 96 m ram (I'm pretty sure thats enough for the program)
I have a number of modules connected to a Roland 4x4 USB midi interface and upon play back of a track the data stutters/jumps/glitches (whatever the word is), this happens every now and again it's not continuous,but nevertheless very frustrating when it does
Anyone have any suggestions ??
Old 07-05-2000
lkmuller lkmuller is offline
Senior Member
lkmuller is on a distinguished road
Wink
I had the same problem. Try cutting back on your hardware acceleration in the control panel - that cleared it up for me.
Old 07-05-2000
AlChuck's Avatar
AlChuck AlChuck is offline
Been Here, Posted That
AlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond repute
Unhappy
thewaiter,
I had the same problem when my machine was a Pentium MMX 200 MHz, also with 96 MB RAM. It seemed to be unaffected by the hardware acceleration setting of the video card. I created a second hardware profile so that I could boot with the modem and the network card disabled (normally the network card would connect me to the network at the office through a DSL connection). I also made sure that none of the resource-stealer things were running -- like FindFast, the Windows Scheduler, the antivirus scan software, etc. Worked fine until I got past five or so audio tracks, which prompted me to upgrade recently to a screaming PIII-700 with 256 MB RAM.
-AlChuck
Old 07-05-2000
Newbie
Wink
I almost feel like doing the same ditching the P2 200 and getting a faster bigger model but haven't got the wedgeo at the moment so I'll have to tweak a few things, can you explain the hardware acceleration ?
Old 07-05-2000
AlChuck's Avatar
Wink
Please excuse me if I don't get this precisely right as I'm not in front of my Windows 9x machine right now...
Go to Control Panel and double-click on the Display icon.
Click on the Settings tab. You should see a buton labeled "Advanced" in there. Clock on it.
In the dialog that pops up, there should be a hardware acceleration slider (can't recall if there are tabbed pages in here or not) that goes from "None" to "Full," I think, with maybe 2 in-between settings. Adjust this downward if it's up at Full and close the dialog box (click Apply if there's a button so labeled) and the others that got you there. You might have to reboot for this change to take effect.
Also check the Cakewalk website if you have a PCI video card -- it could be hogging the PCI bus. There's a FAQ or technical article about what to do about this for various video cards; perhaps yours is on the list.
Good luck!
-AlChuck
Old 07-06-2000
nubius nubius is offline
Junior Member
nubius is on a distinguished road
Wink
The only video cards I know of that hog the PCI bus are the Matrox Millenium series. There is a setting you can change in WIN.INI to correct this (intentional) problem.
If you have one of these *older* cards, then lowering the hardware acceleration might not help. It could be a DMA buffer size/cache/HDD block size issue.
Old 07-06-2000
AlChuck's Avatar
Wink
nubius,
My MagicVideo PCI card on the old computer had this problem -- I think all S3-based video cards do, at least potentially. Was the Matrox Millenium based on the S3 chip?
-AlChuck
Old 07-07-2000
Junior Member
Wink
No idea! Probably...
Old 07-07-2000
AlChuck's Avatar
Unhappy
Sorry I overlooked mentioning this before... one more thing that might cause such behavior -- in my last machine, I had two newer 32 MB SIMMs and two older 16 MB SIMMs for a total of 96 MB; it was a slow machine (Pentium MMX 200 MHz) and I couldn't reliably get even a track of audio, with the same behavior you describe.
Eventually I decided just for fun to take out the two 16 MB modules... and suddenly I had a DAW that worked. It was no screamer, mind you, but it could record 6-8 tracks and run a couple of plug-ins without problem.
I had read somewhere that even though motherboards say they support it, sometimes using memory of different speeds or types can cause performance issues. I had some that was faster than the other and some that was EDO, some that was not.
-AlChuck
Old 07-12-2000
Newbie
Wink
I also use two 32MB chips and 2 16MB chips, bugger maybe I should try that also.
You guys have mentioned probl;ems using audio I DONT even use the PC for audio recording! my souncard is a soundblaster AWE64.
I shall try some of the tweaking mentioned above thanks
Old 07-12-2000
John Sayers's Avatar
John Sayers John Sayers is offline
Solar Power!!
John Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond repute
Talking
It's probably not a windows problem but for all you guys and gals this is a good site for basic windows setup for audio
http://www.musicsolutions.com.au/art...ngwindows.html
  #12
Old 07-24-2000
Newbie
Wink
Well I tried a couple of things but still having troubles. I have the computer linked up to a Roland SMPU 4x4 if I am transmitting
over 4 midi outs with patch changes going on and filter information being transmitted, is it possible that my PC is just not powerful enough ??? I am using Cakewalk Audio 6 I have a Pentium2 200mhz and have 96meg RAM ?????
