Old 01-11-2003
gatorhaus's Avatar
gatorhaus gatorhaus is offline
Dedicated Member
gatorhaus is on a distinguished road
Buying a Compressor
I am wanting a dual channel compressor to run while tracking the kick drum and bass guitar. I was looking at either the DBX 266 or the Behringer Composer. $100-150 price range.
Any thoughts out there.
Larry
Old 01-11-2003
Richard Monroe Richard Monroe is offline
Been Here, Posted That
Richard Monroe has a reputation beyond reputeRichard Monroe has a reputation beyond reputeRichard Monroe has a reputation beyond reputeRichard Monroe has a reputation beyond reputeRichard Monroe has a reputation beyond reputeRichard Monroe has a reputation beyond reputeRichard Monroe has a reputation beyond reputeRichard Monroe has a reputation beyond reputeRichard Monroe has a reputation beyond reputeRichard Monroe has a reputation beyond reputeRichard Monroe has a reputation beyond repute
Nooo, Mr. Bill! You're too close to being able to buy an RNC. It's pretty much the only game in town. It can compress 2 channels, but not with discrete and separate controls. However, at $179, RNC is vastly superior to all similarly priced units IMHO. Check FMR Audio at Macmidimusic.com. Until you have a lot of money, you won't see a more versatile and effective compressor.-Richie
Old 01-11-2003
mixsit mixsit is offline
mixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond repute
What are you recording to, and how/what are you going to mix it on?
Is software compression at mix time (instead of while tracking) an option?
At that price range, it could be a better and more versatile way to go.
Wayne
Old 01-11-2003
gatorhaus's Avatar
Dedicated Member
Wayne,
I am recording through an Aardvark q10. Using samplitude as my multitrack software.
Yes software compression is available. But I was wanting a more even recording during tracking. Esp. for bass I usually see on some of the less expensive basses some bands use It will peg out on the open E and low signal levels on the other strings. Which is the main reason I wanted to compress during tracking.
Thanks,
larry
Old 01-11-2003
tyler657recpro's Avatar
tyler657recpro tyler657recpro is offline
Force of Nature
tyler657recpro has a reputation beyond reputetyler657recpro has a reputation beyond reputetyler657recpro has a reputation beyond reputetyler657recpro has a reputation beyond reputetyler657recpro has a reputation beyond reputetyler657recpro has a reputation beyond reputetyler657recpro has a reputation beyond reputetyler657recpro has a reputation beyond reputetyler657recpro has a reputation beyond reputetyler657recpro has a reputation beyond reputetyler657recpro has a reputation beyond repute
I second the suggestion of the RNC. It should work well for most basic things you might use it for, and you will probably keep it for a long time.
Old 01-11-2003
sponge bob sponge bob is offline
Senior Member
sponge bob has a reputation beyond reputesponge bob has a reputation beyond reputesponge bob has a reputation beyond reputesponge bob has a reputation beyond reputesponge bob has a reputation beyond reputesponge bob has a reputation beyond reputesponge bob has a reputation beyond reputesponge bob has a reputation beyond reputesponge bob has a reputation beyond reputesponge bob has a reputation beyond reputesponge bob has a reputation beyond repute
I third the RNC. The only other comp I really like in this range, (but getting harder to find) are the Symetrix 501's. Very simple, great sound, definately an E-bay item. Seen em for $100 every once in a while.
But... for the life of me , I can't believe how cheap the RNC is, and why they haven't jacked the price yet!
RNC... trust me.
Sponge Bob
Who lives in a pineapple under the sea?
Old 01-11-2003
MISTERQCUE's Avatar
MISTERQCUE MISTERQCUE is offline
Not Just Anutha Brutha
MISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond repute
Thumbs up
RNC is also more than sufficient on bass ! When I first purchased the unit, I basically used it for subtle comping at mixdown or occasional track processing.
Using the Composer Pro on bass 1st , provided adequate levelling and peak control, but it came up weak when using the percussive, thumb-slap technique where using a fast response
and hi thresh should have afforded me what I was looking for.
The RNC is handled that particular bass technique with effortlessly
w/o the unwanted sound artifacts found in most comps in that price range.
Old 01-12-2003
And it can do excellent double duty later on stereo sub-mixes and main mix.
Old 01-12-2003
gatorhaus's Avatar
Dedicated Member
Thanks all for your replies, looks like the RNC for me.
larry
