Old 06-23-2000
mutt's Avatar
mutt mutt is offline
Dedicated Member
mutt is on a distinguished road
Question
I can't seem to record into Cakewalk with my Compaq Presario 2200. It has a cheap soundcard with only a 1/8" mic input (no line in). I've connected my mic (SM58) to my TASCAM 564 4 track, then from the line outs of the TASCAM to the mic in on the computer. I've checked to make sure the mic volume is up on the computer and it's not muted, but no luck. I can't even get the mic to record to the internal sound recorder on the Compaq. Any Compaq users out there have any ideas??
mutt
Old 06-27-2000
Torpid-x's Avatar
Torpid-x Torpid-x is offline
Tonal Scientist
Location: Experimenting with your deoxyribonucleic acid
Torpid-x has a reputation beyond reputeTorpid-x has a reputation beyond reputeTorpid-x has a reputation beyond reputeTorpid-x has a reputation beyond reputeTorpid-x has a reputation beyond reputeTorpid-x has a reputation beyond reputeTorpid-x has a reputation beyond reputeTorpid-x has a reputation beyond reputeTorpid-x has a reputation beyond reputeTorpid-x has a reputation beyond reputeTorpid-x has a reputation beyond repute
Wink
Have you tried recording with a mike?
Rich
Old 06-27-2000
mutt's Avatar
Dedicated Member
Wink
Yes - I can record to cakewalk if I hook a cheapo Radio Shack computer mic directly to the mic input on the computer, but when I connect using my TASCAM as a board connected to the 1/8 mic in on the computer, I get a very faint signal. I've turned everything up as far as it will go.
mutt
Old 06-27-2000
AlChuck's Avatar
AlChuck AlChuck is offline
Been Here, Posted That
AlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond repute
Wink
You should be using the line in on the soundcard, not the mic in.
-AlChuck
Old 06-27-2000
mutt's Avatar
Dedicated Member
Wink
I don't have a line in - just a mic in and a headphone out
Old 06-28-2000
Middleman's Avatar
Middleman Middleman is offline
Professional Amateur
Middleman has a reputation beyond reputeMiddleman has a reputation beyond reputeMiddleman has a reputation beyond reputeMiddleman has a reputation beyond reputeMiddleman has a reputation beyond reputeMiddleman has a reputation beyond reputeMiddleman has a reputation beyond reputeMiddleman has a reputation beyond reputeMiddleman has a reputation beyond reputeMiddleman has a reputation beyond reputeMiddleman has a reputation beyond repute
Wink
Sounds like impedance mis-match. The only way you will get the results you are looking for is to disable the Compaq soundcard and get a different brand which is designed for recording music. Most new soundcards have either a line-in or rca audio jack.
Good Luck.
Old 06-28-2000
darxide darxide is offline
Newbie
darxide is on a distinguished road
Post
considering you said you can record, sending a mic directly to the mic-in of your sound card, but not when you connect your 4-track to the mic-in.. the only thing i can think of to check, is the line-out levels/volumes of your 4-track, and check your cable, that, i'm assuming, translates from a 1/4" out of the 4-track, to the 1/8" mic-in of your sound card..
another thing to note, is that the mic-in's of a cheap sound card, generally out-put in mono (even if it's only receiving a left-channel signal, it will out-put left and right mono; whereas, the line-in will only out-put a left-channel).. just might be something to take in consideration. i have a compaq presario, but i also have a line-in (a cheap sound card also), and i've never tried using a mic-in, as a line-in.. so i know very little of how it works, and what you have to do, to make it work--
gl
(as i reach the end of this post, i glance back to your post, which says "I've checked to make sure the mic volume is up on the computer and it's not muted, but no luck.", and i wonder if you have the volume for recording turned up and _selected_, rather than just the playback volume.. if not, in your Volume Control, go to Options/Properties, 'adjust volume for _recording_', and make sure 'Microphone' is checked at the bottom, and click OK.. check the 'Select' box under the mic controls and adjust the volume.. if that was the case, i'm wondering how you got decent recording with a mic directly connected to the mic-in..
just a thought-- gl)
