I just got and installed an 80 gig hard drive into my computer for music purposes. My primary hd is a smaller 12 gigs. The 80 gig as now is my slave.
Can I set Cakewalk Sonar 2 up so that it saves to my 80 gig slave rather than my 12 gig primary? Thanks! btw - windows 2K. Andrew. |
yes you can, you go to options->global and then go to the folders tab, and set it for a folder on your 80gb hardrive
also, you should plug in the harddrives such that the main system drive and audio drive are on different ide channels. The system can only access one device per channel at any given instant, so the audio hard drive and system hard drive cant be accessed at the same time if they are on the same channel, therefore defeating the purpose of having two drives. Just hookup the cables, and adjust the jumpers, so that the system drive is the master on the primary ide channel and your first optical drive is its slave, and your audio drive is the master for the second ide channel, and your second optical drive, if you have is its slave. Eric |
thanks
Thanks Eric, I got it running now the way I want in terms of hard drives. The rest of it is another ball of wax. Keep chugin' and thanks!
Re: second hard drive
Edit: Sorry Kingston, I should have read your reply more fully. Looks like you already gave him that same advice. My apologies. |
Vice |
But for your purposes, I defer to the two suggestions prior. |
Thanks, Earl |
If you have them on the same controller the instructions for both drives have to go through the same controller and one can interfere with the other. |
Thanks Dachay, I understand. It's basically to let windows do it's thing to avoid meesing up mine!
Vice |
Thanks KRock!
#12
dachay2tnr- Thanks for your advice. I really should switch them around, it's a bit laziness.
What interference could be caused by having them on the same controller like you said? |
#13
It's not a big deal and you'll be OK as is. But if you want to best optimise two hard drives for audio, they should be on separate controllers. Having them on the same controller is not much different than having a single hard drive - except you have more storage space. |
#14
That's what I figured, but it still would be good to switch it now, before I start acruing files and gigabytes that I might nuc in the process. Thanks again.
