question about backing up sonar audio tracks to cd
my computer crashed the other day and i thought i made a back-up of my audio tracks to cd.when i loaded my tracks back to my
pc,it reloaded all my track settings etc, but no audio was found.i believe i saved my songs to disk as bundle files.how do you back- up your unfinished audio tracks to cd so you can work on them later?thanks |
Do you know that the audio data is stored in a seperate directory found under 'options' 'global'?
But if you saved a bun file and then copied that to a cd, it should have included the audio. (The bun file should have been quite large compared to a 'project' file.) I don't know if you can save-as a bun without getting the audio.(?) Wayne |
Even after a crash most of the audio should be on your hard disk. You can try and find the files and insert them into the tracks (that's what I have to do from time to time). OK, I know it's a pain, but it may be your only chance.
As for backing up, storing bundle files on CDR(W) is the safest approach imho. |
Re: question about backing up sonar audio tracks to cd
As mixit indicated, bundle files are quite large. You should only have been able to get one, or maybe two on a CD. If you had more than that on the CD, that's another indication they were project files. Backing up your songs as bundles is a good idea. You can do that to CD or to another hard drive. Usually a good idea to open them one time after creating them, just to make sure everything is OK. |
