Old 01-03-2003
mcmd mcmd is offline
Senior Member
mcmd has a reputation beyond reputemcmd has a reputation beyond reputemcmd has a reputation beyond reputemcmd has a reputation beyond reputemcmd has a reputation beyond reputemcmd has a reputation beyond reputemcmd has a reputation beyond reputemcmd has a reputation beyond reputemcmd has a reputation beyond reputemcmd has a reputation beyond reputemcmd has a reputation beyond repute
Question Which upgrade path do you recommend?
I am currently running Guitar Studio 2.0 and want to upgrade to 24 bit recording. So, do I choose guitar tracks Pro or Home Studio 2002?
My normal recording process, never requires more that 2 inputs, - because (like most) its a solo effort, - just me and my guitars.
My current audio card is the 16 bit DMAN PCI (from MAUDIO/MIDIMAN) and has a Roland wavetable, which I have used for midi drums with session drummer.
It looks like I will get the Echo Mia 24/96 card, - which has no midi.
Both GTPro and HS2002 support 24/96 recording, right?
I already have Audio FX-1 (which is also included w/ HS XL)...so I think it all comes down to which package has the best drum capability?
GTPro has no midi and bundles a lite version of Fruity, and I don't know much about HS2002, it has session drummer, but what do I use for a wavetable/samples?
Anything else that I should be considering?
Thanks in advance,
Dara
Old 01-03-2003
brzilian brzilian is offline
2.5K Gold Member
brzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond repute
HS2002 only supports 24bit/48Khz audio.
Old 01-03-2003
Senior Member
brzilian,
Thanks for the info.
Funny, how Cakewalk makes you dig for the most important specification!
...its looking like GTPro
...24/48 maybe be OK, but I'll never know, if I go with HS2002...
Thanks,
Dara
Old 01-03-2003
Paul881's Avatar
Paul881 Paul881 is offline
Look Mom, I can play!
Paul881 has a reputation beyond reputePaul881 has a reputation beyond reputePaul881 has a reputation beyond reputePaul881 has a reputation beyond reputePaul881 has a reputation beyond reputePaul881 has a reputation beyond reputePaul881 has a reputation beyond reputePaul881 has a reputation beyond reputePaul881 has a reputation beyond reputePaul881 has a reputation beyond reputePaul881 has a reputation beyond repute
Before you part with your $$$, you might just like to consider why you are intending to record at 24/96. 24/96K uses one hell of a lot of diskspace and for what benefit? Once you export to Wav, will you be able to tell the difference between 24/48 and 24/96? I can't and I know many others who can't either.
Old 01-04-2003
bamboo bamboo is offline
Senior Member
bamboo is on a distinguished road
I agree with Paul here. If I were you I'd invest the $$ in Sonar 2.1.
Old 01-04-2003
Senior Member
Paul881
...so 24/48KHz is the recommended trade-off between quality and file size...thats go info...and I will probably also settle on this rate
...so I can upgrade to GTPro for $29, not sure if I can upgrade to HS2002 ( may just have to buy it)
...But
bamboo
...an upgrade to Sonar 2.1 is $199!!
...why would I want Sonar? What does it do for that extra $171, that I could take advantage off?
I want to get something that meets my requirements,...no more no less.
Thanks,
Dara
Old 01-05-2003
Paul881's Avatar
Originally posted by mcmd
Paul881
HS2002 gives you the ability to record midi as well as audio. Good for synth work. You should be able to upgrade, its a superb package.
...But
bamboo
Sonar gives you a lot more fx and tools. If you check out the Cakewalk web site, there ius a chart there that lays all the differences for you. IMHO, I think you might be better off going for HS2002 and then upgrading to Sonar later, if you need to.
Thanks,
Dara
Old 01-05-2003
Teacher's Avatar
Teacher Teacher is offline
do unto others......
Teacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond repute
24/96 has more top end bite, the difference is more audible when micing something such as vocals. Also if u use plug-in 24/96 sounds more open and less muddy or veiled then 48 or 44.1
all in all things seem to sit better in the mix in 24/96 but this can also be due to me gettin better as a mixer...
"...if the opposite of pro is a con lets go beyond this, the opposite of CONgress must be PROgress..." Cage
Old 01-05-2003
Paul881's Avatar
Teacher, if ya can hear that much difference, I have total respek for ya ears and gear man.
Old 01-06-2003
Teacher's Avatar
what i'm hearing also can be me just becoming a better mixer
but the vocals do have more high frequencies, alot less high frequency boost to "air out" the vocals..at least thats how it sounds to me...i didn't do any mathematical equation or whatever to figure it out also reverb sounds way better at 96 then 44.1
