Old 01-02-2003
jeff0633 jeff0633 is offline
Senior Member
jeff0633 has a reputation beyond reputejeff0633 has a reputation beyond reputejeff0633 has a reputation beyond reputejeff0633 has a reputation beyond reputejeff0633 has a reputation beyond reputejeff0633 has a reputation beyond reputejeff0633 has a reputation beyond reputejeff0633 has a reputation beyond reputejeff0633 has a reputation beyond reputejeff0633 has a reputation beyond reputejeff0633 has a reputation beyond repute
Smile Just ordered VF-160CD, now questions
Howdy.
I just ordered a new VF-16 CD. Now, I have a few questions. Can I write individual tracks to a cd as a wav file and then put them on the computer for editing in Cool edit?
Can a few of you comment on the built in effects? What about the compressor? What do they mean when they say Track compressors? Does each track have it's own compressor, or is it a single compressor that all tracks are run through.
Any more info about this machine would be appreciated.
Jeff
Old 01-02-2003
ShadowKat ShadowKat is offline
Newbie
ShadowKat is on a distinguished road
Question New Owners of Fostex VF160CDR
Jeff: I also ordered, for the second time, the VF160CDR from Musician's Supply as a "scratch and dent" or otherwise known as a "blemished item" for the sum of $699.00. The reason for the 'second time' is because the first time, they sent me a defective unit. I would not have known that had I not plugged the unit in when it arrived with nothing connected to it (just to see it display) and the led peak light on channel "B" came on and stayed on. So I e-mailed Fostex and told them and they got back with me in less then 24 hours and told me it was defective, and channel "B" was dead. So I sent it back, and was about to order a portastudio cassette, when I saw another "blem" became available, and should arrive here tommorrow. I have never owned a digital unit before, and realize that there is a "learning curve" to it all, so any information on quick set up for "simo" use and other tips from current owners would be greatly appreciated. I need to throughly check out all the functions to be sure I don't get screwed with a "defective unit." Let me know when you get yours, Jeff.
Old 01-02-2003
PeteHalo PeteHalo is offline
Dedicated Member
PeteHalo has a reputation beyond reputePeteHalo has a reputation beyond reputePeteHalo has a reputation beyond reputePeteHalo has a reputation beyond reputePeteHalo has a reputation beyond reputePeteHalo has a reputation beyond reputePeteHalo has a reputation beyond reputePeteHalo has a reputation beyond reputePeteHalo has a reputation beyond reputePeteHalo has a reputation beyond reputePeteHalo has a reputation beyond repute
Congratulations to you both for a smart choice. There's plenty of info of how to use your VF160 to the max already on this forum. So please read the previous posts carefully dealing with VF160 or VF16 and you'll have much of the info you need already before you get your hands on your machines.
Old 01-02-2003
theletterq theletterq is offline
Dedicated Member
theletterq is on a distinguished road
Yes you can write individual tracks as wav files.
The effects are less than stellar (pretty digital and artificial sounding) but if you really do some tweaking and experimenting with the presets, you can get a pretty good, usable sound.
The compressor really only works when used very judicously. I really don't like to use it for anything other than a limiter. It works like this: You can have it set up for EITHER tracks 13 and 14 or tracks 15 and 16. The master channel has it's own "independent" compressor. Also, you cannot use EQ or effects on the compressed tracks which can be worked around by just bussing the tracks if you can get them set how you want them.
Overall, despite a couple of shortcomings (for most of which there are work arounds via outboard gear, etc) this is a good, solid, cheap, great sounding, quiet machine. Good luck.
Old 01-02-2003
Senior Member
That's good. I will get an outboard effects unit as soon as I can. Maybe the Behringer Virtualizer. I also use a J-station, so I could use that for effects in a pinch.
So you can record it compressed, and then move those tracks to other tracks, freeing up the compressor for the next tracks? I also have an RNC compressor, so I am sure i will be using that mostly.
Old 01-02-2003
Senior Member
Smile Re: New Owners of Fostex VF160CDR
Hi. Wish I would have known about that price. I got mine for $799.00, new and sealed in the box.
We need to stay in touch with each other so that we can experiment with our new machines. I have a Mackie 1202 VLZ pro. I plan on adding another one so that I will have 8 decent mic pres for 8 tracks at once. That should be plenty for recording any band, so I'm not even going to worry about getting the adat interface for 16 tracks at once.
I am tore between two recorders. I almost decided on the new Zoom 1266 without CD. It is $749.00, and I could have gotten someone down to 700, and then I could have added the USB card for it for a 100, and that would have let me transfer tracks to the PC like that, and you can record 6 tracks at once with it, and it has built in drums and bass, 24 bit, 20 gig drive. But, the tracks that I heard done on the VF-16 and VF-160 sounded better for some reason. They sound full, and huge. Why would a 16 bit recorder sound better to me than all the 24 bit recorders I hear out there? Did I make the right choice?
Hear was some of my thinking. Though the zoom is 24 bit, has drums and bass, and great effects, I can add a nice effects unit to the Fostex for not much money, and I can easily stick a bigger drive in it, can't I? Would it hold a 40 gig drive? if so, I could add a bigger drive, then the adat and another 8 channel board along with two Mackie 1202's, and I would have a full 16 track at once recorder with 40 gigs of space and a nice effects uni, plus a burner in it and also be able to transfer everything to the computer for mastering. So, i think the Fostex gives me more options for the future, cause i can add to it with outboard stuff, and have a pretty nice 16 tracks full studio. I also need to pick up 4 SM57's to add to my two Marshall 603's that I have. I also have a SP C-1 mic as well for vocals. My first objective is to be able to record an entire band at once using 8 tracks. So I need tghree sets of thisngs to do that. Four SM57's along with the 603 small condensers, one for a guitar amp, and one for a bass. And I also have an SM58 for a scratch vocal. I also need a decent effects unit, and another 1202 VLZ pro. That will get me started. I also have the Alesis active studio monitors. This would be a nice mobil setup, so I know what I need to do.
Anyway, lets help each other out on our new machines.
Jeff
Old 01-03-2003
Dedicated Member
Before getting any new mixers take a look at the products like the Presonus DigiMax LT. For $799 you'll get 8 quality preamps that can take mic or line level signals and you can connect it to VF with a single TOSlink cable.
You're damn right about the Fostex giving you more options for the future. IMHO the VF160 is the only recorder giving you options as the others give you restrictions. Don't worry about the fact that VF is only 16 bit because internally it's 32 bit as all the others. You did the right thing as you bought performance and features not hype and bells and whistles. There's thousands of great records made with 16 bit technology in the last 20 years and we're talking about home recording here.
Old 01-03-2003
to_see_me to_see_me is offline
Newbie
to_see_me is on a distinguished road
I am in the process of selecting a digital recorder myself. I hear the fostex units are made very sturdy. Plus, for not much more money than an some 8 tracks I could buy the vf-160. Are they pretty intuitive?
edit:what is Musician's Supply website? that's a great price!
Old 01-03-2003
Dick Flansen Dick Flansen is offline
Junior Member
Dick Flansen is on a distinguished road
Check it out, American Musical Supply has open-boxed, NO CD versions of the VF160 for $649! http://www.americanmusical.com/item....=NFS+FOSVF160X - I bought one last night. Of course, I'd love to have the cd, as exporting wav files to zip drive or whatever is going to be a pain... But, I couldn't pass up the price, and I've seen the cd drives on ebay for $129. Just HAD to get my hands on it, for that price!
Does anybody care to comment on the mic pres on this thing? For my application, I'm a couple channels short on outboard pres and will end up having to use xlr transformers on the first few channels (maybe, say, some sm57's on toms). Until I get a few more quality preamp channels, is the built-in stuff even useable? Any better or worse than maybe a cheap little Behringer mixer or something?
Old 01-03-2003
Junior Member
Er, I mean, $659. Close enough.
Old 01-03-2003
Dedicated Member
The pre's are pretty quiet...nothing more, nothing less. I go straight in with drums and achieve satisfactory results.
  #12
Old 01-03-2003
Junior Member
Are you doing the same thing I'm thinking, using dynamics with xlr transformers on the first 6 channels? There's enough gain, there? Just checking.
  #13
Old 01-03-2003
Dedicated Member
Well I do what everyone tells you not to do which is just using a simple XLR - 1/4 cable. Yes there is a little noise and loss of fidelity here and there but for my current situation, it works and I don't plan on doing this forever. I can always edit any stray noise out of silent parts, etc. I haven't had any problems at all with enough head room on the drums.
Also, I've started getting out of my "live" micing mindset and have really started realizing how much of my sound comes from the overheads. I'll soon have a good preamp on those and will probably end up forgoing tom mics all together which will leave me with kick and snare on another pre. Then, I'm pretty much set.
Good luck...
  #14
Old 01-04-2003
Mip's Avatar
Mip Mip is offline
Junior Member
Mip is on a distinguished road
Hey,
I was just wondering, are standalone hard-disk recorders like the Fostex, Roland (VS), and Yamaha (AW) products useful for if you want to mix synth sequences with audio tracks?
How would you go about it? Would you sync a synth/sequencer to a drum machine/click track, to keep the sequences in time?
I studied audio at the SAE and we only used computers running Protools so I haven't had any experience with standalone units.
What made you guys get a standalone unit instead of a computer setup? It's probably just a matter of what you want to record, etc., but i've always just assumed that computer recording setups would be far more powerful, and easier to use.
  #15
Old 01-04-2003
Junior Member
For me, it's strictly for portability - e.g., track drums with it in a decent room, bring the tracks home to my computer system to overdub everything else. Yes, I would absolutely think that a computer recording setup would be far more powerful, and easier to use - but these units are pretty slick for, say, a mobile rig.
  #16
Old 01-05-2003
bbbmusic bbbmusic is offline
Junior Member
bbbmusic is on a distinguished road
Go to www.vf16.com
Tons of people there
  #17
Old 01-05-2003
Dedicated Member
When I bought my Fostex VF16 in fall '01 I had a crappy 200MHz CPU and equally crappy Soundblaster and I thought I'd be better off with a standalone. As I had no previous experience of standalones at that time I had a pretty hard time to decide between the VF, an Akai DPS12i and some Roland unit and the main reason I went for the Fostex was the fact that it used the cheap 3.5" ide HD instead of the much more expensive (at that time) 2.5" laptop drive the others use.
Afterwards I've been pleased with my decision but not because of the 3.5" HD but the ADAT interface that I had no use for at that time. Then I got a new computer and a Terratec EWS88D card in order to be able to hook the VF up to computer thru the ADAT interface and that was the moment I realized the real potential of this computer/VF combo. I use the VF16 for the basic tracking and then I transfer the tracks over to computer thru lightpipe for editing and final mixdow in n-Track. Even if I need to overdub a part directly in n-Track I can use the VF16 as a recording mixer and track to computer using Fostex's Adat mixer mode without having first to track on VF and then do the transfer. Going for the VF16 in the first place has enabled me to utilize the best features of both worlds at a very reasonable price. The portability of standalone and the editing and mixing capabilities of a computer DAW is a combination that's pretty hard to beat. Now it's all up to the guy sitting behind the desk.
Talking about ease of use, a week ago I lended my Fostex to a 16-year-old kid who has since then recorder 3 songs with his friends and tomorrow he's returning it and we're going to transfer the tracks to my computer and do the final mixdown of his songs and burn a CD. When he picked it up I gave him a quick rundown of the basic tracking procedures for about half an hour and now he's already tracking like a pro.
  #18
Old 01-05-2003
mrx mrx is offline
Force of Nature
mrx is on a distinguished road
It really depends on your computer - what most people won't tell you (until it's too late...) is that computer recording can be "inconsistent". If you get the drop outs resolved, then ultimately your money is best spent on the finest A/D converters you can buy.
Integrated units resolve the "drop out" issue by tuning the hardware to the OS - in other words, you won't lose a great take when your email take priority over your DAW.
Regardless, there is no substitute for editing on a computer. Check out all your options - the Fostex MR-8 is $299 and lets you record CD quality audio and seamlessly share with a PC. Many find that ability to affordably extend your DAW's reach to make for a compelling combination.
  #19
Old 01-06-2003
Dedicated Member
If your looking forward to recording real drums, using condenser mics or do tracking more that USB cable's length away from your computer then I advise you to stay away from the MR8. Unless you're ready to spend hundreds of dollars for memory cards you're pretty much tied to the computer and for the price of MR8 you could get an multichannel soundcard for your computer instead.
  #20
Old 01-06-2003
mrx mrx is offline
Force of Nature
Pete wrote "...or do tracking more that USB cable's length away from your computer..."
It's fine to be a VF-16 fan, but giving false information helps no one. The MR-8 makes a great addition to a computer based system because it's so convenient, portable, and easy to use that you'll be more willing to carry it with you (everyday I'm tempted to bring it to work with me...). Also, the price makes sense as an addition to a larger system.
Of course if you need to record a fully mic'd drum kit...
  #21
Old 01-06-2003
Dedicated Member
I was merely referring to the fact that you need to be close to your computer to backup the recorded tracks to it. Armed with the 25 minutes (divided by the 8 tracks gives a whopping 3 minutes per track) of track time that a 128MB card offers you need a laptop if you want to record out of the house.
  #22
Old 01-06-2003
mrx mrx is offline
Force of Nature
It still goes back to what you need, and how you record. True, if you are tracking vocals remotely and are working on several songs at once and want to keep multiple takes, several harmonies, etc., then space might get tight on an MR-8 with any card. On the other hand, what about one song and one instrument? I recall reading that Kansas spent a week in the studio just getting the guitars on "Dust In The Wind" recorded - the thing I'm working on now requires similar care be taken with the acoustic guitar and I find the MR-8 goes everywhere my guitar goes. Yes, I've collected some good takes and eventually archived them to computer, but I have also spent considerable time away from the computer working on arrangement and performance - with the MR-8 'practice' turns into 'recording'.
Not to say the same thing couldn't be done with any recorder, but in my experience the equipment "pain threshold" is very low - if something is a bother it just doesn't get used.
  #23
Old 01-06-2003
bluesbear bluesbear is offline
Newbie
bluesbear is on a distinguished road
I have been recording to my PC for three years and I have grown
sick of the software problems, the clicks, the blips, the expensive
plug-ins. After upgrading to Win2K and facing with a $1000 dollar
bill to upgrade soundcard and software I am going the PC less
route as far away from Bill Gates' Evil Empire as possible.
So I have been comparing the MR8 with the VF80. I don't really
understand why people think the VF80 is so difficult to use.
If you just want the MR8 functionality it is just as easy to use.
The effects on the VF80 are an entire century ahead and it is
difficult to believe the same company makes the MR8.
Musiciansfriend sells the MR8 for $299 and the VF80 for $499.
If I buy an MR8, a 256MB card and a preamp so I can use a
condenser microphone I am paying more than 500 bucks and I
still have only about ten minutes of eight track time as opposed to several hours and the preamp to lug around. The VF80 has
built in phantom power. Heck for $699 I can get a CD burner built
in, and I may just forget about Windows for good.
No more clicks, pops, squeals, ooooh yeah!
  #24
Old 01-06-2003
mrx mrx is offline
Force of Nature
That last post is a perfect example of how people get in trouble by purchasing without understanding the facts. By 'ease of use', I'm not talking about learning to use the buttons, but rather how the unit fits into how you work.
The VF-80 brochure clearly states that transfering tracks to a PC requires the Fostex CD-ROM drive. Not only does that jack up the, price, it's a retarded way of working in conjunction with a computer. If I had to burn a CD every time I wanted move tracks, I'd throw the thing through a window. Of course some will say you can use the digital IO, but what are the limitations there (besides having to move tracks 'real time')? Can any track(s) be moved this way, or just a final mix?
This may be fine if your goal is to leave the computer behind for good, but at that point you'll want a unit with more muscle than the VF-80.
  #25
Old 01-07-2003
Dedicated Member
Which brings us to the fact that the VF-16/160 platform gives the most bang for the buck. If you can get a Vf160 for less that $700 on your side of the pond I wouldn't think for a minute of getting anything else. It's true 16 track (no stereo tracks) with 8 track at once (16 with external AD if needed) recording capability and the ADAT interface makes it easy to connect to computer or other pro systems.
