Old 01-01-2003
strev strev is offline
Newbie
strev is on a distinguished road
smoother groove clips?
My dilemna is: I've been experimenting with creating groove clips (creating say 4 or 8 measures on the Midi w/ staff view and then converting to audio). After creating the groove clip and stretching it (to make it repeat) there seems to be a very minute pause. It doesn't effect the overall rhythm is quite noticeable especially I have groove clips of the same measure length. How can I make it sound seamless as it does on the simple looping feature?
Old 01-01-2003
gms9's Avatar
gms9 gms9 is offline
Al Lurker
gms9 is on a distinguished road
smoothing groove clips
there's a couple of factors involved:
1. if your levels and breaks on a groove clip don't match, you're going to get some deviation in what the rhythm sounds like. one way around this is to set up a repeat/loop on the number of measures you need and record until it loops. then clean up any transients so that you get a clean transition between loops.
replay the recording tyo make sure it sounds consistent before applying the grove clipping to it.
(then remove the looping from cakewalk so you can hear the transitions between the groove clips)
2. you may not need the "splicing" feature so it you're not planning on altering tempo, you can slide the splicing slider to 0. this eliminates some odd effects that happen when the audio transitions across the slice...
__gms
Old 01-01-2003
brzilian brzilian is offline
2.5K Gold Member
brzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond repute
Re: smoother groove clips?
That usually happens to me when Snap To Grid isn't enabled. Make sure your snap settings are set to snap to a measure.
