PA9 File Destinations
My audio drive fried so maxtor sent me a new one. I'm trying to write files on D to store audio/MIDIetc. as described in Cakewalk Power.
I managed to arrange this with the previous drive, but this time CW refuses to recognize the new files. What I did is create the new files, then copy & paste the files from C to D. I also rewrote the destinations in Global Options for everything to go to D. But when I try to save that arrangement CW says no and renames all the files back to C drive. Do I need to delete the files from C drive after copy/paste to D and eleminate those file paths? Is it possible to do thatin CW?? I know there was a trick to this from the last time because it took a few tries then as well. Thanks. |
Are you trying to write the .wav files, or the project files (.bun/.wrk)? It makes a difference.
If I recall in PA9, one of the defaults was located in Global Options, but the other was located in Options > Audio. If it's the .wav files, I believe you need to reset the default directory in Options > Audio. (At least I think so. It's been a long time since I've used PA9 and I have very few brain cells remaining that still have any functionality. ) |
Yo, Suspended seventh...
I found using Cakewalk Audio Finder make it easier to manage your Cakey's file... it's free download. Older version : http://www.prorec.com/prorec/downloa...2565F80062EC3D Newer version : http://www.cakewalk.com/Support/SONA...loads.asp#CWAF Hope it helps... ![]()
Keep Rockin' and Rollin'...
