Lowering Backround Noise!!!!
I have an AKG SolidTube and an Art TubeMP preamp running into my computer running Nuendo and sometimes CEPro2. Im recording in a closet, but I added a few elements to deaden the reverb in the room. For some odd ass reason when I record vocals in the booth I get this electric humming backround sound that sounds like a television interference when you try to watch a channel you don't have. When I raise my recorded vocals the sound shows up and makes the audio sound bad. I can do noise reduction in cool edit, and it disappears... but!!!!!!
Here is my question, since I have Waves Native Bundle and other software Noise Gates, Compressors, and stuff; is it possible of me to add some kind of effect to the track im going to record to before I record, so that I can bypass the backround noise without having to run a Noisegate or Noise Reduction after its recorded??? The Noise Reduction process is so tedious because it takes about a 1 minute to remove the noise from each vocal track. HELLLP!!! LOL. |
You really should trace down the cause of this noise rather than try and fix it with noise reduction before or after it gets to tape.
Does this noise only occur in that closet? Does it occur outside of it? Have you checked the obvious like shitty cables, dimmer switch interference or any type of EMI interference? Do all mic's do this or just the ST? Is it the MP? I'd remove all these variables first, before considering any type of noise reduction. I record in a rather noisy room, computers, traffic etc, but I know they are there and what the sound is, and how to live and work around it. Find out what is causing this buzz. |
The Solid Tube is going to have its own power supply and doesn't require phantom power from a mic pre. You're not by some slim chance feeding phatom from the ART to te mic are you?
Do you have a flourescent light in the closet or anywhere near your rack?
Well I know its not the cords because i purchased new ones since. There is no florencent lights or phantom power. I have a regular closet with clothes everywhere. Not sure what EMI Interference is, but I noticed that when I turn down the input and/or the output on my preamp, the sound disappears. I can even hear the sound when its not recording; when I have my microphone on, you hear the annoying sound through my speakers. I have Mackie824's so I dont think they could be causing interference. What do you guys think?
R,
It is the tube MP. I have one that I use all the time for Bass guitar and it is very picky about the relationship (gain staging) between the input gain and output gain. Use your ears. Turn up the input gain about half-way (and while listening through headphones or?)then start turning up your output gain until you start hearing that hum,then back off a little. If this doesn't push the gain stucture to what you like (for tube sound) readjust your in-out relationship. You will always find a sort of sweet spot where you have a near dead quiet relationship until you push it a little further and then you will have the hum. For what it's worth. |
also try turning off your computer monitor, and any other tv or computer monitor anywhere near where you are recording.
Someone mentioned before that they lived near some sort of broadcasting tower of some sort, maybe a radio, or cell phone transmitter, and they picked up the noise in their tube mp. Im sure its not this case, and most likely what was said about about the mp. I find i get a lot of noise from the TUBE MP as well, but i haven't really used it because of this. I want to replace the tube i think mine maybe befaulty. but i have had it for a year so good luck to me bringing it back.
The Lands End Road Project... |
Im glad to see Im not the only one suffering. Well its like this... I tried playing with the input and ouput controlls to have it so I dont hear the hum; what happens is I have to compensate for low volume signal on my vocal tracks. I only bought the TubeMP to amplify my signal because without it, virtually no sound comes through to my sequencer. I have two Mackie824's, a Radioshack mixer, and the AKG Power souce thing for my SolidTube mic; all in the same area. Could this cause the hum? Maybe, huh? Let me know if you have any more tips or inexpensive advice. Thanks guys!
try plugging the mic into a seperate outlet?
or maybe the preamp too, or something like that. i heard someone talking about that in another thread and it seemed to quiet it right up. But it may have been a different situation.
Actually you want all of your rack gear and computer stuff on the same circuit. This eliminates ground loops in your supply voltage.
Conditioning may help. Also, check your ground on your outlets to make sure it is properly connected. If your outlets aren't grounded that is going to be where you start having problems. |
hmmm
it's me again.
originally posted by raydio Quote:
FL STUDIO 6 REASON 3.04 KNOIZE POLLUTION SOUNDKITS CUBASE SX 3.0 http://www.moneyistherecipe.com/imag...ution-logo.jpg CHECK OUT MY WEBSITE FOR BEATMAKING VIDEOS AND MORE WWW.MONEYISTHERECIPE.COM
#12
check this
originally posted by slackmaster 2000
this is where i got it from http://homerecording.com/bbs/showthr...t=soundblaster check the rest out if you wish
#13
I had the same problem with my Studio MP. I did a few things that took away most of it.
I think the main thing was i plugged it into a different power socket, and it's now about 10 feet away from my computer and speakers. Also i got a new mic cable, but i doubt that helped. Give it a shot, you don't loose anything buy plugging it into a different socket.
#14
I had a similar problem, different amps but similar prob. The solution was so simple it's almost funny. I simply had things sitting too cloce to each other and was picking up hum from one amp to another. The transformers set up electrical and magnetic fields that other amps will often pick up. A little rearranging and spreading out got rid of about 98% of my hum, if you have the space, you might want to give this idea a try before spending a bunch of money to solve what might be a simple problem. You might want to check and be sure that everything is grounded really well, even one weak ground can cause hum and make your gear succeptable to outside interference.
