Go Back   Home Recording > User Forums by Brand > n-track User Forum
     Audiofanzine Music-software Music-software News Music-software Medias Music-software Tests Music-software Articles Music-software User Reviews Music-software Classifieds Ads
Old 12-17-2002
MichaelF MichaelF is offline
Newbie
MichaelF is on a distinguished road
Record levels
Ok, here's a question from a confused newbie. I'm using n-Track with an OmniStudio/Delta66. When using the Line ins 3,4 on the OmniStudio, where/how can I adjust recording levels? Or, are they "fixed" because they're at line level? I have set the "record level" for Line ins 3,4 on the Delta Control Panel. Is that all I need to do?
Mike
Old 12-17-2002
Slackmaster2K's Avatar
Slackmaster2K Slackmaster2K is offline
Gone
Slackmaster2K has a reputation beyond reputeSlackmaster2K has a reputation beyond reputeSlackmaster2K has a reputation beyond reputeSlackmaster2K has a reputation beyond reputeSlackmaster2K has a reputation beyond reputeSlackmaster2K has a reputation beyond reputeSlackmaster2K has a reputation beyond reputeSlackmaster2K has a reputation beyond reputeSlackmaster2K has a reputation beyond reputeSlackmaster2K has a reputation beyond reputeSlackmaster2K has a reputation beyond repute
You should be adjusting recording levels before they even touch the Delta. Using the Delta or n-Track to adjust recording levels is not advisable - leave those levels at 100%.
The reason is that if your signal is coming in too hot, lowering the recording level does NOT prevent clipping, it just lowers the level of the clipped signal. Also, this level adjustment is digital, and you want to be doing as little digital gain reduction as possible (you'll be doing enough mucking around during mixing anyhow).
The best way to control levels is at the source. If your mic level is too hot, then turn down the preamp. If the preamp signal is still too hot (in the case of drums or super loud guitars, perhaps), then you'll need a pad somewhere. etc etc
Slackmaster 2000
Slackmaster 2000
