when i insert a wav into Cakewalk6, i get a "pitch/distortion" sound when it's played back. Is there a certain setting i should have on the Audio Options?? Has anyone ever had this problem before?? i am using a SoundBlaster Live card. THanks.
Sounds like maybe what you are recording is being played back through the Live's
output and then back into the input again. This causes excessive signal gain (distortion) as well as a phase problem since technically there is some delay there in the two signals. I had that happen to me when I was playing with some new ideas on how to hook up my mixer. Are you using a mixer in which you monitor through headphones? If so, and your card is set up for full-duplex operation (most are), then you will need to inspect your hookup and signal flow closer. Good luck...pete o |
