Very straight foreward questions. Thinking of the following purchase's.
Cakewalk Pro Audio 9 Roland Audio Canvas for vocals and guitars drum mcahine synth/midi controller microphones. cd recorder/burner Question is:how does everything interact or better yet, will it interact together. Thanks in advance |
Sounds like a good plan....here's a quick description of how everything will coincide,
though there are various ways to hook things up. I'm not familiar with the Roland. In a nutshell.... Cakewalk 9 (which I have) records two formats: MIDI and audio. It can deal with both at the same time. Your controller is a good way to input MIDI notes into Cakewalk. You will need the synth and drum machine to actually create the sound that the MIDI note generates. A good sound card can also create this sound. Cakewalk allows you to send notes to these various sound generators simultaneously. For the audio, Cakewalk is capable of recording through the soundcard input (or your Roland) into mono or stero tracks. This is where your mics will come in. One thing I recommend is a small mixer with aux sends and returns. The mixer allows you to adjust levels on the fly and connect to the card with one cable. It can act as sort of a patch panel that prevents you from having to connect to the back of your computer all the time. I have basically the same set up and I use the Peavey RSM mixer. Some folks prefer Mackies but in my opinion the new RSM is better for the money. Speaking of Peavey, Cakewalk and Peavey made a joint product called the StudioMix. It's a programmable mixing surface that basically takes the Cakewalk on-screen mixer and places it on your desk. It gives you real knobs and motorized sliders to work with. I have one of those too and it's great to work with. If you buy the StudioMix you get Cakewalk with it. I recommend buying Cakewalk that way. If you go to buy the StudioMix later it will still come with a version of Cakewalk (that you will be paying for). Finally, Cakewalk can mixdown all your tracks for you and make a stereo wavefile. This file can then be burnt to CDr with your burner. Then you can play your music on a consumer CD player in your home or car. Hope this helps.....pete o |
Pete, checked out the Studiomix and purchased it today.Thanks for the direction!!
