I have my cakewalk 8.0 pro audio. I use
it to mix my audio files with midis and it works quite well. The only problem I have is when I want to put some of the effects in the mix. It makes the procedure, shows me the sample and when I click on OK, the computer change the audio file (taking a long time in this procedure) and then it sounds dry again (no effect) What am I doing bad? Can somebody explain to me the correct procedure? I appreciate it a lot. Thanks! |
I'm not exactly sure whats going on but I'll try and help. Couple of questions; are you trying to process audio files?.What kind of computer do you have.All specs.RAM Etc. Describe your steps previous to trying to process the audio in more detail and I'm sure some cakewalk guru in here can help if I cant.K
Talk to ya, Bill L&M [This message has been edited by LMSTUDIO (edited 08-23-1999).] |
hi and thanks for your reply.
I was editing an audio file. my proceed was: I recorded the audio from my tascam line out to the SB 64 PCI line in. It was recorded yust fine in a audio track. I listened to it to be shure it was recrded fine and it was. The record is about 5 minutes long. Then I went to the edit place in the screen, chose audio effects and aplyed ambience reverb. The program shows me the 5 second sample and it was what i expected. Then i click in OK or porceed (i dont remember) and tha computer take about a minute changing the audio file. When it finish the audio track looks like a big and wide line but when i press play it becames the same as it was and it sound the same that it sounded. My computer is a celeron 300 MHz 64 Mb Ram 6 Giga HD 32X cd rom SB 64 PCI soud card Midi man external interfase for keyboard that´s it. I hope you can help me thanks a lot!! |
make sure you highlight the track you want to
put the effect on before you go to the effect and hit ok |
You beat me to it.Thats what I was thinking too.Make sure the portion of the track you want to be affected is highlighted.But will it allow you to select effects in the menu if nothing is highlighted? I thought it was greyed out and wouldn't allow you to click on it if nothing was highlighted.I dont use CW effects too often.
From what he is saying, the audio file is changing to a larger wave due to the effect applied, but yet it's not audible. Are you sure the reverb isn't there. Try different settings or diff. reverbs and see if those work.Try other effects like delay just to experiment. See what happens.I'm guessing, but if it has a dry level setting, make sure that the dry level setting is not higher than the reverb setting.I dont have CW in front of me right now but I will look as soon as I get to the control room tonight. Bill |
simple question.
Perhaps i just haven't had enuff experience with cakewalk yet, but from what i can tell, if you want to use an effect, you can't add it and hear it while recording, you have to add it afterward. Is this true? If so, how am I supposed to know what kind of sound i want? Is there a way to change this? thanx. |
