Old 07-25-1999
davexxxxx davexxxxx is offline
Junior Member
davexxxxx is on a distinguished road
i recently lost some songs i had saved to Cd
with cakewalk.bun files.
i did not close the cd after burning.
i then wiped my hard drive.
now my cd burner will not recognize the data.
any sugestions?? Is there any third party software helpfull in closing out the cd so
it can be read????
pleeeese help if you can
dave
Old 07-25-1999
drstawl's Avatar
drstawl drstawl is offline
5K Californium Member
drstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond repute
My only suggestion- and my condolences on the fact that this is a posthumous solution:
Monitor the burned copy before you wipe the material on the HD. That's why I dump to CD only .wav and .wrk files from CW projects. The playback can be automated to check the entire disk by using CW playlist for the .wrk files and any .wav player for the .wav files.
[This message has been edited by drstawl (edited 07-26-1999).]
Old 07-26-1999
Dragon's Avatar
Dragon Dragon is offline
Large and Scaly Mixing Maniac
Dragon has a reputation beyond reputeDragon has a reputation beyond reputeDragon has a reputation beyond reputeDragon has a reputation beyond reputeDragon has a reputation beyond reputeDragon has a reputation beyond reputeDragon has a reputation beyond reputeDragon has a reputation beyond reputeDragon has a reputation beyond reputeDragon has a reputation beyond reputeDragon has a reputation beyond repute
I have Adaptec Easy CD Creator and one of the options there lets you close the CD. If you don't want to buy that you can send me the CD and I'll do it for you, but no guarantees on the results, of course...
Old 07-27-1999
Junior Member
i have adaptec full version
but the burner won't recognize the cd
since i wiped my hard disk
i can't close it out if it doesn't see it
it just keeps trying to read it but can't
any suggestions???
Old 07-28-1999
Dragon's Avatar
Did you try recovering the files with Norton Undelete or something?
Old 07-28-1999
Emeric Emeric is offline
Emeric has a reputation beyond reputeEmeric has a reputation beyond reputeEmeric has a reputation beyond reputeEmeric has a reputation beyond reputeEmeric has a reputation beyond reputeEmeric has a reputation beyond reputeEmeric has a reputation beyond reputeEmeric has a reputation beyond reputeEmeric has a reputation beyond reputeEmeric has a reputation beyond reputeEmeric has a reputation beyond repute
Whether you close the session or not, you should still be able to read it. Sounds like a bad burn to me. However, you could try dragging any file to the unreadable CD-R, in Adaptec EZ-CD. If it will let you drag the file there, your other files should magically appear. If so, burn again with the new file. It may correct itself, but I have my doubts.
Take Dr. Stawl's advice, always check the copy before doing something irreversable like a format. It's easy to wipe data. I'll admit I recently killed a month's worth of work using some 3rd party partitioning software.
Best of luck,
Emeric
Old 08-14-1999
Junior Member
hey guys got my data back.
it was some wierd problem with my cd burner.
it totally messed up my system.
got it straightend out,and was able to see and restore my music data cds!!! whew!!!d
Old 08-16-1999
drstawl's Avatar
Then you got a very inexpensive education in archive procedure. Most folks have to pay for this with months of lost work. You can confer your own degree...
