Go Back   Home Recording > User Forums by Brand > Sony Tools / Sonic Foundry
Reply    Audiofanzine Sony Sony News Sony Medias Sony Tests Sony Articles Sony User Reviews Sony Classifieds Ads
Old 11-21-2002
JonnyD JonnyD is offline
Newbie
JonnyD is on a distinguished road
Exclamation Question About Notching
First of all, I mostly do IVR's and on-hold systems. I record the talent with SF-6, then convert the files to whatever format the client needs using Vox Studio 3. I always record at 44.1- 16 Bit mono. Here is what the client has asked for: "Also note that when the OA Server converts the wav file it can only
work in the frequency range of 300HZ to 3000HZ. Any frequencies below or
above this range will introduce a hissing sound or other undesirable
noises." So my question is, can I notch out those frequencies above and below what he has requested?
Thanks,
JonnyD
Old 11-21-2002
MONTE's Avatar
MONTE MONTE is offline
Dedicated Member
MONTE has a reputation beyond reputeMONTE has a reputation beyond reputeMONTE has a reputation beyond reputeMONTE has a reputation beyond reputeMONTE has a reputation beyond reputeMONTE has a reputation beyond reputeMONTE has a reputation beyond reputeMONTE has a reputation beyond reputeMONTE has a reputation beyond reputeMONTE has a reputation beyond reputeMONTE has a reputation beyond repute
You should be able to use the paragraphic eq in sound forge to get the job done. Just enable the low and high shelves, set them to the desired frequencies, and cut them all the way.
