Go Back   Home Recording > Equipment Forums > Keyboards and Sound Modules
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 11-17-2002
Phyl's Avatar
Phyl Phyl is offline
Master of the Obvious
Phyl is a splendid one to beholdPhyl is a splendid one to beholdPhyl is a splendid one to beholdPhyl is a splendid one to beholdPhyl is a splendid one to beholdPhyl is a splendid one to beholdPhyl is a splendid one to behold
Sustain Pedal and MIDI Recording
I recently started using a sustain pedal with my MidiTech keyboard. I've programmed the keyboard to treat the pedal as a sustain pedal. The keyboard is connected to a Roland sound module and when I choose a piano patch the pedal seems to work as expected, after I strike a key and let go, the note sustains until I take my foot off the pedal.
I'm confused about how the pedal is controlling sustain. When I record a MIDI performace in which I've used the sustain pedal and then look at the MIDI notes in SONAR, I don't see the MIDI notes stretched out where sustain was used and I don't get the sustain effect when I play the performance back unless I turn the sustain pedal on, and then eveything gets sustained.
Is this how it's supposed to work? If not, what am I doing wrong?
What exactly does the pedal "tell" my sound module when I turn it on?
Old 11-17-2002
Krakit's Avatar
Krakit Krakit is offline
Rzzzzz!
Krakit has a reputation beyond reputeKrakit has a reputation beyond reputeKrakit has a reputation beyond reputeKrakit has a reputation beyond reputeKrakit has a reputation beyond reputeKrakit has a reputation beyond reputeKrakit has a reputation beyond reputeKrakit has a reputation beyond reputeKrakit has a reputation beyond reputeKrakit has a reputation beyond reputeKrakit has a reputation beyond repute
You module is told "sustain pedal = ON" when you depress it and "sustain pedal = OFF" when you step off it.
When you play the MIDItech is it connected to the Roland and then to the computer?
Are you using the THRU port or the OUT port?
Carl
“The modern conservative is engaged in one of man's oldest exercises in moral philosophy;
that is, the search for a superior moral justification for selfishness.”
-John Kenneth Galbraith
Old 11-17-2002
A1A2's Avatar
A1A2 A1A2 is offline
1K Silver Member
A1A2 has a reputation beyond reputeA1A2 has a reputation beyond reputeA1A2 has a reputation beyond reputeA1A2 has a reputation beyond reputeA1A2 has a reputation beyond reputeA1A2 has a reputation beyond reputeA1A2 has a reputation beyond reputeA1A2 has a reputation beyond reputeA1A2 has a reputation beyond reputeA1A2 has a reputation beyond reputeA1A2 has a reputation beyond repute
if you look at the MIDI track in...ummm, I forgot what it's called in Sonar, but if you open it in the "MIDI-numbers-view" opposed to piano view, you will see something called sustain or "hold" at the part where you press sustain pedal and its the same when you depress your pedal.
I hope this helps, really can't remember what that window is called, but in ACID, it's under MIDI property, i think
AL
Old 11-17-2002
Phyl's Avatar
Thanks Krakit and A1.
I've got the MidiTech midi out connected to my Aardvark Q10 midi in, the Aardvark midi through is connected to the Roland MIDI in.
Like I said, when I play a SONAR track back, it doesn't seem to know that I ever used the sustain pedal, like it's not recording the depression of the sustain pedal. I'll play with it some more, I'm obviously missing something.
Old 11-17-2002
Phyl's Avatar
Oops - brain fart on my part - SONAR is recording depressions of the sustain pedal just fine. So I really don't have a problem, although I did learn something new about my sound module and SONAR.
Thanks guys.
Old 11-21-2002
TexRoadkill's Avatar
TexRoadkill TexRoadkill is offline
Audio Bum
TexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond repute
If you want to see the sustain pedal data you need to be able to view the midi controller messages. I can't remember the number for sustain but it is recorded the same as Volume, Pan, Patch Changes, etc. You can edit the sustain pedal data later if you need to which is cool.
Bookmarks
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright © 1995-2010 Audiofanzine except where noted. All Rights Reserved.
