Old 11-01-2002
Justin.Irish Justin.Irish is offline
Newbie
Justin.Irish is on a distinguished road
DBX Digital Dynamics Processor/Compressor DDP
Hello,
I wanted to let you know I just put my DBX Digital Dynamics Processor/Compressor DDP up on Ebay with a really low reserve of only 179.99. http://cgi.ebay.com/ws/eBayISAPI.dll...item=917452431
Heres a little info on the DDP:
Dbx Digital Dynamics Processor
dbx® Digital. . . now the possibilities really are endless. The dbx® DDP offers you the processing power of digital, with the great sounds you know and want from the analog world. Plus, with digital technology, we can offer you more precise control and extended parameters than you could ever have with analog processing. The DDP gives you a true stereo processor, coupled with dbx® True RMS Power Summing technology, or two independent mono units, giving you the versatility and power of processors costing many times more. Gating, compression (yes, with OverEasy®, all-new VariKnee, or good ol' hard knee thresholds), limiting, de-essing and EQ (both in-path and sidechain) are available in the DDP in any order you want. The possibilities are endless. The LCD display shows you all the information you need to know, complete with a digital meter that will blow your socks off, featuring peak and average levels at the same time.
Wouldn't it be nice if you could see the effects of your entire setup in one place? They are displayed visually in the form of a graphical curve on the right side of the display, making it a snap to set up even the most challenging of systems. In fact, it works right out of the box, no Ph.D. required, with 50 great factory preset setups to help you get started. The DDP's operating system offers you the ability to refine and save presets to your liking then name and save them as your own presets for later recall. Wide-ranging gain controls allow for both +4 and -10 operation, without any effort on your part. The 8-step analog LED ladders show you exactly what is coming in and going out of the DDP. Metering on the display shows the effects of the processing on the signal in real time. Audio performance is also top shelf, with ultra-wide range 24bit A/D and D/A converters with dbx® TYPE IV™ Conversion System featuring TSE™ (Tape Saturation Emulation) right on board. Digital input/output is also available as an option, giving you the ability to go all-digital. Full MIDI SysEx automation functionality makes the DDP one of the most versatile processors on the market today.
Features
· All the classic dbx sounds in gating, compression, limiting, de-essing, and sidechain EQ
· The most extensive metering available
· Graphical representaion of signal shows composite effects in real time
· TYPE IV Conversion System with TSE (Tape Saturation Emulation)
· 24bit A/D and D/A convertors keep your signal pristine
· "Building Block” style operating system lets you build and save your own presets
· Digital input/output option
Cheers, Justin
Old 11-05-2002
Newbie
Smile
Only 1 day left!
Cheers, Justin
