Go Back   Home Recording > User Forums by Brand > Roland, Boss, VS Series Forum
Reply    Audiofanzine Roland boss Roland boss News Roland boss Medias Roland boss Tests Roland boss Articles Roland boss User Reviews Roland boss Classifieds Ads
Old 09-21-1999
discordJF discordJF is offline
Newbie
discordJF is on a distinguished road
I currently own a roland vs-1680 without the expansion boards. I want to buy and outboard noise gate and possibly even a compressor/limiter. Are these ouboard pieces compatable with the 1680? If they are, please explain how I can hook them up to the 1680. If they're not, is it just more conveneint to buy the expansion boards?
Old 09-29-1999
asibob asibob is offline
Newbie
asibob is on a distinguished road
Smile
You can hook up outboard equip. to the Vs-1680. I have wired in a compressor and reverb successfully. The manual does not make it easy though. Use the aux inputs through the master section of the mixer and read each line in the manual carefully!
Old 09-29-1999
Newbie
Smile
Old 09-29-1999
Newbie
Wink
could you tell me where in the manual I could find the info on how to hook up outboard gear.
Old 10-25-1999
phatstadt phatstadt is offline
Newbie
phatstadt is on a distinguished road
Wink
I have the FX expansion modules in my 1680, which includes a noise gate. However, you can only use the effect by inserting it in the mic line that needs the gate. Unlike other effects such as delay or reverb where you can use the effect send/return bus.
This is fine except that you can only gate one microphone at a time. I found by given that the gate is a stereo effect, I can link 2 inputs with mics in them an create a stereo channel with 1/2 or 3/4 etc... I can then apply the nose gate to the stereo linked channel. So this enables to insert the gate into 2 mic lines. However, I have not found a way to do this for multiple inputs say for live recording of 4 mics.
Looks like I would need outside pre-amps for all the mic lines, then outside gates, then input into the 1680.
Is there a way to do 3 (or more) noise gates using the built-in effect of the 1680?
Philippe H.
Old 11-19-1999
Larry Sheehan Larry Sheehan is offline
Junior Member
Larry Sheehan has a reputation beyond reputeLarry Sheehan has a reputation beyond reputeLarry Sheehan has a reputation beyond reputeLarry Sheehan has a reputation beyond reputeLarry Sheehan has a reputation beyond reputeLarry Sheehan has a reputation beyond reputeLarry Sheehan has a reputation beyond reputeLarry Sheehan has a reputation beyond reputeLarry Sheehan has a reputation beyond reputeLarry Sheehan has a reputation beyond reputeLarry Sheehan has a reputation beyond repute
Wink
Have a look at phrase split (added in v2.xxx). It can be after the fact to gate out signals below a threshold. Takes some experimenting, but I have used it when my external gates weren't set up right to save a track.
Old 12-06-1999
Dmusic2 Dmusic2 is offline
Newbie
Dmusic2 is on a distinguished road
Red face
hey all,I have a 1680 w/efects bords.when you use any efects,as you bounce to tracks 10 to 16 (stereo tracks),you can free-up that efect to be used agian.
