Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 10-26-2002
jb4play's Avatar
jb4play jb4play is offline
Pimp
jb4play is infamous around these partsjb4play is infamous around these partsjb4play is infamous around these partsjb4play is infamous around these partsjb4play is infamous around these parts
Exclamation Does This Make Sense?
Hi? I'm a young producer of Rap and R&b and I have a question. Ok... here goes... I use Cubase SX 1.03 as a HD recorder/midi station/mixin platform/mastering utility, so from the beginning to the end my music is in the digital domain. I've been tracking my Akai Mpc 2k XL tracks, Reason tracks, and vocals mainly at 32/44.1 with true tape at +6db for the longest. But a thought came to my head. WHY!!! This is my new way of approaching things. The Akai MPC 2k XL's convertors can only toss out sounds at 16 bits, so I decided from now on I'm goin to record MPC tracks at 16 bits in cubase, track my vocals at 24 bits, and any tracks within reason that are already 24 bits will be tracked at 24 bits, if not, they will be tracked at 16 bits( I bus the outs of reason out the back of my card into the front so Its like i'm recording reason sounds like an external keyboard, gives it that hardware sound so it doesn't sound like software all the time). My problem is... is this reasonable? Mixing 16 bit and 24 bit files within cubase? and after mixing i'm plannin on downmixin at 32 bits so I can reload them into cubase or wavelab to master, or down mix at 24 bits if I'm sendin the track to an outside masterer who can't work at 32 bits. PLZ let me know if this sounds like it will work. thx
Old 10-28-2002
lomky lomky is offline
So much to learn
lomky has a reputation beyond reputelomky has a reputation beyond reputelomky has a reputation beyond reputelomky has a reputation beyond reputelomky has a reputation beyond reputelomky has a reputation beyond reputelomky has a reputation beyond reputelomky has a reputation beyond reputelomky has a reputation beyond reputelomky has a reputation beyond reputelomky has a reputation beyond repute
You cannot mix bit rate or sample rate in Cubase.
Old 10-28-2002
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
Not only that, but 32-bit is an internal CUbase representation used for higher-res processing.... the files remain at 24-bit..... there's no such thing as 32/44.1, 32/48, 32/88.2, 32/96 files outside of Cubase and other s/w that uses higher internal word sizes.
